Help needed
Hello all
I have a few questions about my 97 GT I wanted to know if any of you here knew of any websites where I can buy a ford factory car alarm for my 97 Mustang GT. Also, Im having problems with my front passenger side turn signal. If I put the turn signal switch all the way up it doesnt flash but the rear passenger side does. If I hold it (before it clicks to hold itsself) both work. If I put the switch all the way down for the driver side both work. I have checked all bulbs and fuses and all is working. I know it could be the switch itself, but is there any wiring I should check. I really dont want to buy one and install it myself because of the airbag(fraid i will make it come out). Thanks for the help |
sometimes having a bulb out can cause weird problems like that. but you say is only when it clicks into position. then i would guess its the switch.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
Re: Help needed
I have seen my share of faulty muti-function switchs on the Fox Bodys, so It wouldn't suprise me if that's the problem on yours as well.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
