Old 10-26-2003, 08:26 PM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
Paint problems
I had planned on air brushing the boday, and just using a small brush to paint the little things. however, tonight i tried to paint the engine and the paint is very thin and dried sort of transparent. I didnt use primer first, could this be the problem. P.s. i was using Testors Acryl, it came with the spray gun i bought.
Old 10-26-2003, 08:32 PM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
Re: Paint problems
Did you shake it up at first? You need to shake up most acrylic paints, because they are water-based.
-Henry-
Old 10-26-2003, 09:25 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Re: Paint problems
stir them. durh.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 10-26-2003, 10:54 PM
the rest of the paints are fine but the one color is really, thin.
Its Testors Acryl Royal Blue if that helps...
PS I did shake them up...
Old 10-26-2003, 11:09 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
Re: Paint problems
Originally Posted by sweetwhiteCAV
t
Shaking won't do - you need to stir it well with a toothpick or something similar. At least this is what I do with Tamiya acrylics.
Old 10-27-2003, 08:26 AM
I tried stirring and shaking and i keep getting really thin paint... the paint has a lot of little paint bubbles throught it, is that a sign that its just not a good paint....
(the other colors contain no bubbles, and arent as thin)
Old 10-27-2003, 12:58 PM
Mainomega Mainomega is offline
Re: Paint problems
Bubble get there when you shake the paint. Stir it like the other guys say. Also has the paint settled to the bottom ?
I bought a Tamiya acrylic metalic paint and all the paint had settled to the bottom, I had to shake and shake and stir and stir for ever until it all finally dissolved again. I just stir may paints prior to thinning them and airbrushing them.
Got Something Good ? E-mail me
Old 10-28-2003, 10:47 AM
problem solved thanks guy, i just stirred the stuff until my arm got tired and it came out great..
