Old 10-26-2003, 03:05 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Question Question for those who use pin vises
Forgive me if I'm asking a newbie question, but what do you use to spin them?? Good old finger power, or Tamiya's "Handy Drill" or just a plain old big black and decker type drill? Thanks, guys.
I work slowly!
Old 10-26-2003, 03:10 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
I'm not fimiliar with the Tamiya drill that you mentioned, but for every other pin vise I've seen, including the one I have, it's your fingers that spin the drill.
-Chuck
Old 10-26-2003, 03:35 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Question for those who use pin vises
I dont even know what a pin vise is. Anyone got a pic?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 10-26-2003, 03:40 PM
bigfrit's Avatar
bigfrit bigfrit is offline
good ole finger power does it for me too.
Cause you don't need to make holes big as craters.
And a pin vise is basically a smallish pen sized thing where mini drill bits can be put in and tightened (don't have a pic)
Can advise everyone to buy some , they are a fabulous craft toy.
Olivier
Old 10-26-2003, 03:45 PM
doh! Was @ Home Depot today i shoulda seen if they had any pin vises. They seem like they could come in handy (also should have gotten primer )
Old 10-26-2003, 03:52 PM
I don't think that you'd have any luck trying to find a pin vise at Home Depot-it's more of a hobby shop item.
http://www2.towerhobbies.com/cgi-bin...?&I=LXL466&P=7
I posted a link to Tower, and one of the pin vises I found there-if you are interested in buying one from them, go and do a search for 'pin vise'-you'll get a lot results, with the main difference being how many bits you get. HTH
Chuck
-Chuck
Old 10-26-2003, 04:10 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Finger power. They're for such find drilling you shouldn't need anything else. But if I were to get a new pin vise, I'd be sure to get one with a top that turned, it wold save some wear on the palm of my hand.
Old 10-26-2003, 07:46 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Re: Question for those who use pin vises
Don't buy a cheap one, because it won't hold a drill bit straight down.
Hiroaki Fukuda
Old 10-27-2003, 02:57 AM
OrangeR's Avatar
OrangeR OrangeR is offline
AF Premium User
Send a message via AIM to OrangeR
Tamiya has two of them, the black one wont hold "big" drills bits like 2mm and + but the white one does, in fact the white one comes with two heads that can manage all of the tamiya drills bits, but as it is heavier and bigger, it is more likely to break pretty small drills like 0.3 mm if you are not very carefull. Well I have broken drills bits with the black one also in a moment of stupidity so don't believe me much.
Rodrigo
Mexico
Hey!!! monkeys can't recreate things with such perfection.
Respect the evolution!!! (message to people making fun of our hobby)
Old 10-27-2003, 04:13 AM
chrismcgee's Avatar
chrismcgee chrismcgee is offline
WWW.ELITESCALECARS.CO.UK
i have a sweet pin vise that has a spiral thread on it, you hold the bit against the plactic and the top, then push down on the central bit and as you push down it spins. very cool
Old 10-27-2003, 04:40 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I have 2 different ones, one is for 0.1mm - 1.5mm and the other is upto 3mm
Steve a.k.a. Hiroboy
Old 10-27-2003, 04:56 AM
chrismcgee's Avatar
i have the same one as hiroboy, very cool. where did you get that box of micro drill bits?
Old 10-27-2003, 06:09 AM
Hiroboy's Avatar
From the LHS
Old 10-27-2003, 03:25 PM
008's Avatar
008 008 is offline
I have one of the double-ended ones and with the handle removed from one end I can chuck the whole thing into a real drill. It's good for drilling many holes, like a brake disc, but you just have to run it real slow. Even doing 8 plug wires on a thick plastic engine is much more pleasant when it's chucked into a drill, as your fingers will get tired from twisting so many times.
I've also seen adapters to use the drill bits in a cordless screwdriver so you can have a very slow, very small drilling tool.
-Ron
