Old 10-26-2003, 07:54 AM
lisamak lisamak is offline
Question newbie 94 civic electrical problem?
94 civic had radio "die-out" for a second or 2 during a 15-minute window last saturday. following thursday evening start car, turn lights on and radio cuts out for a sec as it did previous week (no issues in between). press brakes, lights dim. i think alternator and take a dark, scary ride home with fingers crossed (was in city traffic and stopping / parking not an option).
go to mechanic friday - alternator and battery test fine. there's corrosion on the battery cables that they clear off and all is good. BUT: 1 mechanic says probably the battery corrosion and should be fine now...2nd mechanic says get the electrical system tested out before driving regularly again.
problem is just spent $1K I didn't have on new distributor/rotor and axle boots last week. so - what are the chances it was just the corrosion? what are the chances its a bigger electrical issue? is there a way to dx the electrical system without going to a dealership and spending more $ I don't have?
any help or tips appreciated i'm a little "neurotic" and kinda scared to drive the car but don't have any other way to get to work
thanks,
Lisa and Monkey (my car)
Old 10-27-2003, 07:46 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
if both the alt and battery tested fine, then i agree with mechanic 1, the only other cause would be if somewhere part of your electrical is not grounded properly and was drawing way to much current to run the nescessites like the headlights and shit.
do you have like a monster audio system, or like neon lights and all this other crap on your ride?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-27-2003, 02:15 PM
JakeDrummer JakeDrummer is offline
Send a message via AIM to JakeDrummer Send a message via MSN to JakeDrummer
you have a short someplace in your electrical system. first off do you have any like stuped power suckers going like white trash stereo systems, rice boy neons, baha headlights, etc?? that would be your first step. unhook, shut off or whatever. stock civic electrical systems can't handle to much more than the stock power pull. ok so see if its still there, if it is then take a volt meter, hook it up to the battery and run it inside the car. Then go drive around and see if anything changes. It should probably be around 13-14 volts or so when the car is running. if that checks out and the car is still doing it then its something else asides from the battery and charging system. you might also have a connection that is loose someplace. your next step would be to start pulling fuses out one by one and see if anything changes. if you volts pop right back up when its doing then you know whats causing the problem. It isn't gonna be a quick fix, but you should be able to find it. Good luck!
94' Integra GSR - Built and Boosted.
95' GMC Sierra 1500 Z71- Business Vehicle.
89' GMC Sierra 1500 4x4 - NV4500 Donor, Mud truck.
94' S-10 - Winter Beater.
98' Jetta - Wife's Car.
81' Kawasaki LTD440
OLD/SOLD CARS: 93' Civic (Sold 124k) -- 91' Civic (Dead 300K) --
91' Civic (STOLEN) -- 92' Civic (Donor) -- 90' Caravan (Dead 227k) -- 89' Civic (Sold 289k) -- 90' Accord (Sold 265k) -- 96' Corrola (Dead 174k) -- 99' Beetle (Sold 134k)
Old 10-27-2003, 05:04 PM
Smile
thanks for the tips - much appreciated.
no monster power suckers - only thing other than factory stereo (yes, i'm embarrassed to admit that) is my alarm and remote start and i've had that for 7 years in the car with no problems.
i've been driving since saturday morning (after they got all the corrosion off the battery connections) without any repeats - including driving in the dark with the lights, radio and wipers...so hoping *hoping* it was scenario 1. but will work on the volt meter thing on the weekend cuz til i know for sure i'm gonna hold my breath every time i turn something on
~~Lisa
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
Newbie, weird electrical problem Jetta 2000 rarrea '97 - '03 1 11-24-2004 03:17 PM
89 civic electrical problems jeffshane '88 - '91 Civic | CRX | Wagon | Shuttlee 4 11-01-2003 12:00 AM
90 Honda Civic Electrical Problem Earle Engineering/ Technical 0 09-21-2003 10:44 PM
