Old 10-26-2003, 07:51 AM
tAno116 tAno116 is offline
Heatshield Removal
How do I get the heat shield off. I see the two noticable bolts at the top, but heard other people having a bitch of a time getting them off.
Old 10-26-2003, 12:05 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
Mine was so rusted that i just ripped it off.....i think there is one bolt on each corner you have to take off though....kinda cramped in there to get a wrench on it but wont be that big a deal i dont think
I'm Jordan
My car is the ugliest one on this board
Old 10-26-2003, 12:08 PM
i got the top two off, and i see a third in the middle is that the last one or are there more on the bottom. and does it just pull right out when all the bolts are off?
Old 10-26-2003, 12:14 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Heatshield Removal
Theres one in the middle. You probably have to take your A/C fan out and maybe the radiator out to get to it.
Old 10-26-2003, 01:20 PM
BullShifter's Avatar
Re: Re: Heatshield Removal
Spray the bolts with penetrating & let soak over night, WD-40 would be the last choice. When it comes time to remove, do it when its HOT & the bolts should come out, just watch out - those parts are VERY HOT(nothing like slipping, then cutting & burning your hand in the same spot). If at all possible, its best to use some kind of heat shielding on the e.manifold or header since it does sit right next to the thing(radiator) that is meant to keep your engine cooler. Exhaust manifolds can get hot enough to light a cigarette & if you have a short-ram intake your pulling in all that HOT air which makes you even slower.
Old 10-26-2003, 01:30 PM
alright thanks have a CAI on the way so ill wait till that gets here to take off the finall bolts. any sites that sell cheap projector headlights with a black housing? and i heard that as long as you swap the head light bracket over to the projectors it will fit, is this true? or is it a honda legend
Car under construction. Finally
3.8 Intake Removal problem Jakal Park Avenue 2 05-23-2009 03:19 PM
'00 COUGAR removing dash gw84 Cougar 0 04-28-2009 08:08 AM
1994 b-3000 radio removal zoobag General Discussion 1 04-05-2009 05:22 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
