Old 10-25-2003, 05:52 PM
red_alert753 red_alert753 is offline
what kind of performance to expect from these mods?
hey yall, i was wondering what kind of hp or whp or quarter mile runs or 0-60 can i expect from these mods on a stock gst
Intake System
3" Cat-back exhaust, downpipe and high flow cat
Boost controler set at 14PSI
Upper intercooler pipe with a new blow off
well, thats about it, can i expect more than a 50 whp from these mods? thanks
Old 10-25-2003, 06:22 PM
DSM-Owner DSM-Owner is offline
maybe around 30HP+ if its all high quality parts
95 eagle talon TSI AWD
Currently being rebuilt. Victim of CRANKWALK!
95 Eagle Talon ESI
18" konig rims, full custom exhaust, adjustable coil overs, rear strut bar, Cold Air Intake.
AIM = ATX eVo VII
Check Out My Car
Old 10-25-2003, 06:28 PM
just 30 hp (at least Whp..?:P) from all that? hmm, i guess a new turbo will make things easier eh?
Old 10-25-2003, 09:29 PM
boosting20psi boosting20psi is offline
replie
before you get a new turbo you should think about doing other stuff first like bigger inter cool with full hard pipes biger injectors new intake manifold i think that the turbo should be the last thing to do and any ways i am push 20psi off my stock turbo rebuilt of coures but look into the other stuff fist
Old 10-26-2003, 12:26 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
20PSI on a T25? From what i've heard, efficiency goes down after 16psi, and your turbo will be toast in no time running at 20. Also you don't NEED a bigger intercooler to upgrade turbos, but injectors, pump, wires and plugs would be on my list.
Old 10-26-2003, 01:31 AM
SpyderEclipseGst SpyderEclipseGst is offline
Re: what kind of performance to expect from these mods?
Yep i have a 97 spyder gst and my mods are everything cept internalls and turbo upgrade and FMIC. And im still slow. Just get your usually intake/exhaust/downpipe/boost controller/ fuel pump then go 16g....Im recently going turbo upgrade. But non the less I have did everything to get ready for the turbo upgrade
GT35R Tuned GSX Spyder.
Old 10-27-2003, 12:48 PM
kjewer1 kjewer1 is offline
AF - Advisor
Intake System
I ran a 14.2 at 94, and 13.7 at 99 (race gas) on those basic mods. Thats about 250 whp on race gas, which is far more than a 30 whp gain Now, a FWD will get a slower ET, but generally the same or slightly higher trap speed because of the different gearing. You can go to a 14b on stock injectors and upgraded pump, stock IC. And that will be a nice gain. If you get into the 16g and larger you'll need larger injectors for pump gas power (stockers will be fine on race gas) but everyone seems to forget that if you want to max out your setup, OR use larger injectors, you absolutely have to have fuel control. And to use that you need a datalogger. So things start to get a lot more involved. Its your choice, depedning on how far you want to take things.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Help me estimate horsepower expectations for these mods 90gs Integra 21 07-11-2003 02:50 PM
what kind of rims are these? slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 6 11-06-2002 02:07 AM
what kind of rims are these? amy@af '88 - '91 Civic | CRX | Wagon | Shuttlee 1 11-05-2002 09:22 PM
WHAT KIND OF SHOES ARE THESE? (pic) ROCKINtheASTRO COMPLETELY off-topic 11 05-05-2002 04:31 PM
What kind of wheels are these? kicker1_solo Tires and Wheels 2 03-04-2002 11:42 AM
