Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-25-2003, 04:51 PM
RBBH RBBH is offline
Question Stock Valve Springs?
I have a 1995 LS. I just got a 285 cam with 250 lift on both intake/exhaust. I need to know if the stock springs are strong enough to use with this bigg of a cam. I obviously don't want to lose power on some super stiff springs. How stiff are the stock springs? Are they enough to the valves up to 7500 rpm or so?
Old 10-25-2003, 10:02 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Holly shit 285 duration with a 250 lift those are beast cams !!! Holly crap! You are definatly going to need some stiffer valve springs b/c you will be making power to around 8800-9000 rpm, not that the stcok bottem end will hold that kind of rpm, but still valve float from spring bind is very possible. But damn man that thing is going to have more of a lope than my car with crower 404's but it will pull real hard top end
Old 10-27-2003, 11:13 AM
I know
Big ass lobes huh!!!!!!! I am excited to see how they do. I am going to send a head to inline 4 in westminster to have the throttle body, manifold and head p/p. I am going to set the thing on a dyno to see where I can put the power. I appreciate your imput. I called comp cams, the company that ground this bad boys, and the suggested a set of springs for the setup. After that it will be time for fuel issues to be addressed. Thanks for your help.
