Old 10-25-2003, 04:37 PM
nbspindel nbspindel is offline
technical: starter, solenoid?
my 95 gt is hesitant to start. i am not sure if its the starter, or its solenoid, maybe even ignition. it starts eventually but is rather embarrasing. it will turn for about 7 seconds, then i stop and turn it again and itll fire right up. i am just worried that if its the solenoid that it may die on me at any time now and i would be stuck with a car that wont start. any thoughts, advice, experience? i would like to fix this myself, as i can do the work, but cant pinpoint the problem.
Old 10-25-2003, 11:17 PM
my82gt my82gt is offline
starting problems
i wouldnt say its your solenoid, the should be 2 on you car by the way one on the starter itself and one on the fenderwell. whens the last time it had a tune up?
Old 10-26-2003, 01:05 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
i'd tighten and clean your electrical connections - it could be as simple as that.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 10-26-2003, 08:28 PM
mustangkid5 mustangkid5 is offline
Just wondering are you letting the fuel pump to shut-off (finish building pressure) first? that will cause what you are talking about if you dont wait for the pump to have pressure built up then it will crank and crank.
Old 10-26-2003, 10:50 PM
to allow pressure to build, i should just turn the key to on and wait a few seconds? i'll try this. --- which electrical connections are you suggesting i clean and check? are you talking about just wires to the starter, ignition, and perhaps plugs? thanks guys!
Old 10-27-2003, 01:30 AM
battery, alternator and starter connections. I doubt your plugs will be a problem considering that the vehicle does start and run properly - if the plugs were fowl you'd notice a difference in the way your engine behaves.
free hypsi87!!
Dan's White Horse
Old 10-27-2003, 02:16 AM
DavidovSpeedWRC DavidovSpeedWRC is offline
Send a message via AIM to DavidovSpeedWRC
I know most Ford motors have a problem with cold starting, thanks to the fuel pump.
For now try "priming" it like mustangkid5 said, and also check your battery if it sounds slow when cranking over.
If your starter does crap out on you (and you have a manual tranny), you can push start it with some help.
-1987 Mazda RX-7 Turbo II-
Voted #7 in the top 10 cars in 1987 by Motor Trend!
-Driving Sideways Since 2001-
