Old 10-25-2003, 02:05 PM
notenoughmoney notenoughmoney is offline
Send a message via AIM to notenoughmoney
automatic shifting question
I shift into neautral when I am coming to a stop my reason is to save gas and to possible keep wear and tear to a minimun by not having the gear engaged.... any opinions.
Old 10-25-2003, 04:07 PM
BullShifter's Avatar
Re: automatic shifting question
It wears more each time you engage into drive. The engine also doesn't like idling, but whatever floats your boat.
Old 10-25-2003, 08:05 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
completly pointless, your motor is gonna idle at the same speed wether it be in N or D, plus your just chewing up the gears faster by always shifting it like that.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-26-2003, 01:40 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
you waste gas by shifting it to neutral. you know that the process of shifting, though it leads to keeping optimal rpms, if done more than frequently reduces your mileage. The engine uses the fuel more efficiently (more miles/gal) when it is in equilibrium. in other words, you get better mileage when you're cruising at a constant speed (freeway no traffic) verses fluctuating speeds(in traffic). same reason why city mileage is always lower than highway mileage.
best let the auto tranny do all the shifting for you. don't you think whoever invented the auto tranny thought about how things should change when a person is stopped at a light? they probably made it so that when it detects the brake being applied, it reduces the amount of gas for idling, to reduce how much you must apply the brake to stop the auto car from inching forward by itself. even if this doesn't happen, read previous paragraph.
Old 10-26-2003, 08:51 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Actually doesn't it have to do with the fluid? like when you are sitting there the engine isn't rotating fast enough to propel the fluid, it just kind of swishes through it, and when you step on the gas it rotates faster and then is able to move the tranny fluid. hmm this probably isn't the best example but think of a boat propeler in water, if you spin it slowly the boat wont move but the propeller still spinning just not with enough speed to move the water, speed it up and the boat starts moving.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 10-26-2003, 03:26 PM
Buzz1167 Buzz1167 is offline
Send a message via AIM to Buzz1167 Send a message via MSN to Buzz1167
The torque converter is probably what your talking about with all the fluid and "squishing". This device equalizes the tranny and the motor by using fairly viscous fluid spun by the engine side, and picked up by the blades on the tranny side (think of pointing a running fan into a non running fan, the non running fans blades begin to move becuase the running fan is forcing air through them, its basically the same idea except with fluid instead of air). While you idle, your engine is actually working to try to turn the tranny side, but since it isnt moving the engine side just keeps on trying (this is why - if you let off the brake, your car moves.) The only thing stopping it from moving are the brakes. So by disengaging the tranny it lets it freewheel at the same speed, whitch would translate into doing less work while idling, although re engaging the transmission all the time is probably where the extra "wear and tear" would come from. I dont think it would make any reproduceable increases in MPG unless you did alot of standing.
This is also the reason that most stick shifts get better gas milage, beucase the "squishing" is controlled completely by the driver, and usually doesn't happen for nearly as long as it does by the torque converter, not to mention that the manual is probably lighter.
HTH
Buzz1167
Jon N
Old 10-27-2003, 10:19 PM
Sulsa Sulsa is offline
I'll buy Buzz's explaination for a dollar. However, I bet it depends on how long you are sitting still each time, as to whether you save more money in gas, than you spend in repair bills on the transmission.
94 Integra LS
Engine is in the car!
Installed parts
GSR block/head, ARP head studs, eagle rods, Endyn pistons/rings, King bearings, REV stainless valves, Portlfow springs &Tit. retainers, BBK 70mm Throttle body, RC 310cc Injectors, Aerospeed plug wires, generic 2.75" CAI, Civic SI crank pulley, 130amp alternator, Hondata S300 in P72 ECU
01 GSR shocks/springs, 17" Enkei Zenkei's, Homemade Black ABS trunk floor
Mods: Removed AC system, routed Coolant Outside Intake Mani
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
