Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-25-2003, 02:27 PM
nailbender nailbender is offline
Send a message via Yahoo to nailbender
transmission woes
Hi folks,
I have a '86 century w/ th440 trannie. Prob is it will not go in any gear. Fluid is full & clean, filter changed last winter. Never any slip, it just quit moving after stopping at the stop sign by the house. No tow truck Any input on troubleshooting & poss. do-it-yourself would be greatly appriciated. By the way, checked linkage, etc. This shadetree will be in over his head if i have to do a complete teardown.
thanks
nailbender
Old 11-05-2003, 11:07 AM
kluvsk kluvsk is offline
Questions... Does it still start?
Have you checked the neutral safety switch wiring harness to make sure it is still plugged in?
Did you get a "CHECK ENGINE" light before it died?
Is it a column shift or a floor shift?
Old 11-08-2003, 07:16 AM
Re: transmission woes
Thx for the reply kluvsk, yes it starts. only in park and neutral to your second question. had the car 2 yrs. and always get check engine for a few mins., but only on the highway while in OD, and it goes out after a few min. It does have a loccking tourque convertor. don,t know how to test the solnoid tho...........thx again
Old 11-18-2003, 09:39 AM
RABarrett RABarrett is offline
This problem sounds to me like a defective front pump, or some other reason for not moving fluid. I would first check the detent on the trans, making sure it moves like it is going into "detent". I would then drop the pan, looking for blocked filter intake, leaking filter seal, something to locate a leak to the pan. If nothing is found, it may require a specialist... Ray
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
