Old 10-25-2003, 12:50 PM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
b16 ?
what year axles do i use on my y1 tranny w/ y1 haft shaft and bout the fuel line will the si fit on my b16? fuel line that connects to the fuel rail im takin bout.. the one off the b16 has ben cut...let me know thanks..
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 10-25-2003, 01:31 PM
kris's Avatar
kris kris is offline
Off playing with fire.
I assume you have the B16 y1 right?
Your stock fuel line will fit the B16 fuel rail.
Old 10-25-2003, 01:34 PM
90hbvtec's Avatar
Re: b16 ?
yes i have the b16y1 w/ lsd ..what axles should i use witht he y1 haft shaft
tru sohc vtec......
Old 10-25-2003, 01:42 PM
kris's Avatar
Re: Re: b16 ?
Dont know why I asked that, I was thinking the S1. Anyways, 90/93 teg axles should work. You will just have to remove a small spacer on your hub.
Old 10-25-2003, 01:46 PM
91civicDXdude's Avatar
90-93 axles will work, IF you remove the dust ring from the inside of your DX/EX/LX/Si hubs, and also if you use the 90-93 integra intermediate shaft (not half shaft, the half shaft is the axle)
kris's Avatar
Re: Re: Re: b16 ?
Hmm, I might be wrong, since you are using the y1 intermediat shaft.
Old 10-25-2003, 02:52 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Let's take a visit to Hasport, shall we? http://www.hasport.com/Products/Axles.htm
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
