Old 10-25-2003, 12:00 AM
LS-2000-NOS LS-2000-NOS is offline
NEED Advice on engine choice
OK heres the scoop .. had a nasty waterpump failurein my 2000 LS and an overheat problem ,that warped the head on my b18b1 so i got that fixed well it seems the warped head caused the barings to go bad in the bottom end and im just tired of this motor i havent fixed it ... so my question is where is the best place to get a B18c5 (as i am done with LS motors had two ls integra's dont care for them) i want to put the b18c5 in there with tranny how hard is this to do as in when i do the ECU swap and the motor and tranny swap what would i be getting myself into
would i have to run wires through a firewall or would most of the engine clips from the LS wiring that runs through the firewall be suffiecient i have no clue on what would be done so if you guys could point me to a website that shows me this or if someone has actually done this swap and could tell me what i need to do would be REALLY REALLY appreciated
Thanks in Advance for any help you guys can give
Old 10-25-2003, 12:17 AM
hondaracer hondaracer is offline
Re: NEED Advice on engine choice
Personally I don't care too much for the b18c5 motor. It's good but not all that good. I believe you'll need a vtec wiring harness too for that swap. But I don't think you just want to spend that much money for an engine such as the b18c5. But other than that the swap is quite easily done. Have fun with motor.
Old 10-25-2003, 01:31 AM
The Motor i would be buying comes with
Motor
- LSD Hydrolic Tranny (S80)
- ECU (P73)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
Is that All that i would need?
i know i dont need all of these thigns as i have sonme already but oh well
but is the Vtec harness included? as the "engine harness"
Old 10-25-2003, 01:39 AM
i also dont plan on doing mods to it besides maybe an intake
so therefor the more hp i can get out of a stock motor the better i think i know you can do a lot with the b18b1 or the b18c1 and they are cheaper but as i dont plan on doing anything the c5 is prolly where i want to be
Old 10-25-2003, 06:39 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
If you're not planning on doing a build up, and want a fast good motor to drop into a teg, the ITR is the best choice. Aside from running vtec and maybe a knock sensor it will bolt right in.
Old 10-25-2003, 12:37 PM
as you say Running Vtec what would i need to do to do that?
thats about the only thing im worried about i mean im decent with dropping in motors and all but i know nothing about the vtec wiring and stuff so could ya tell me if that means running a harness through the firewall or would i be looking at just clipping the motor into engine harness thats already present ?
Old 10-25-2003, 03:11 PM
You'll need to run hardwires straight from the vtec solenoid to the ECU, not hard. Goto a junkyard and grab a ECU plug with the wires and pins remove the pins, measure how much wire you'll need, solder together the wires, pins and to the vtec plug, and the ECU, then run it through your firewall once you have pinned them to the correct locations in the ECU. Once it is in place, tape it into the loom for a clean factory look.
Old 10-25-2003, 09:56 PM
thanks alot that doesnt sound to bad once i get the motor i may ask you a few more questions youve beebn more than helpful the vtec is about the only thing i figured to be the problem and finding a vtec in the junk yards around here in ohio is gunna be near impossible im just hoping it comes with everything i need already so all i need to do ir run the wires
Old 10-25-2003, 10:20 PM
The wires don't nescessarily have to be from a vtec, they just have to have pins on them
Old 10-26-2003, 01:28 AM
well i called the guy earlier it comes with the harness thats made for the ECU for the Type R so all ill have to do is punch a hole in the firewall and run the new stuff through so its gunna be all plugging in from there it has all the engire clips and everything
Fender Bender - Need Advice on Repairs Panken202 Grand Cherokee | Grand Cherokee SRT8 3 10-24-2010 09:50 PM
Need advice on parts pricing mrfechetto Sable 1 03-06-2009 09:11 PM
Ok I need advice!!! Engine style Ashley Eclipse99 Engine, Transmission and Drivetrain 25 06-18-2007 01:01 AM
FMIC Choice, Need Advice! guitarXgeek Engine, Transmission and Drivetrain 5 05-29-2005 01:19 AM
