Old 10-24-2003, 06:14 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
turbo housings?
can you split the turbo housing apart, and put them back together without effecting the balance of the wheels and shafts??
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 10-24-2003, 07:45 PM
TurbosR4me's Avatar
TurbosR4me TurbosR4me is offline
split the housing 4 wut reason..........?
Old 10-24-2003, 08:06 PM
95_GSX's Avatar
Re: turbo housings?
in order to port the turbo housings, i dont want to have to worry about damaging the internals. so if i could split the housing's apart and it would make porting them easier.
Got AWD?
'08 Buell 1125R
Old 10-25-2003, 09:03 AM
kjewer1 kjewer1 is offline
AF - Advisor
No one has really seen any gains from porting the compressor outlet on a TDO5H compressor cover, which is what I am assuming you are running (14b, 16g, 18g, etc). So you can take the exhaust/turbine housing off without harming anything. Just remove the WG actuator arm, and the bandclamp that holds it to the center cartridge. Its that simple. Just be careful to pull it out squarely so you dont damage the blades on the turbine wheel There may or may not be an alignment pin on the housing/center that will help you align things when you are done, so be careful not to smash that up while porting. The compressor housing could come off by removing that snap ring, but its really not worth your time. Have fun
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-26-2003, 01:31 PM
95_GSX's Avatar
thats exactly what i needed to know. thanks for the knowledge.
Got AWD?
'08 Buell 1125R
Old 10-29-2003, 11:13 PM
95_GSX's Avatar
cracks in my 14b exhaust housing!!!!
i ran into a new problem today, i was screwing around at work and went ahead and split the exhaust housing away from the rest of the turbo and was inspecting it, i looked it over and there is some f*cking cracks, i dont know if this is normal or not. but none of the cracks run into the turbo outlet, or all the way through the housing. but there is 2 that start in my tubo inlet and one runs down like it is going to the fan/wheel and the other runs into my wastegate, this WG crack continues through the center(so essentially the WG has 2 cracks in it). how is this going to effect the perfomance of my turbo?? thanks for the help, i will try to get pics up soon.
Got AWD?
'08 Buell 1125R
Old 10-29-2003, 11:42 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Exhaust side cracks are normal, but compressor side cracks arent. It will take abit longer to spool due to ex side cracks.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 10-29-2003, 11:43 PM
AF - Advisor
Cracks are perfectly normal, even in practically new castings. Again, see the porting vfaq for pictures of the cracks Tom had on that hosuing. I bet your are in the same place. 3 in particular are common. Drive it on
Kevin Jewer
Old 10-29-2003, 11:47 PM
Talon007's Avatar
Normal on the compressor side? Probably from the mass producing
Chris Clark
www.Talon007.com
Old 10-29-2003, 11:52 PM
AF - Advisor
The compressor side should never have cracks. Aluminum is pretty soft... The cast iron on the turbine housing side is brittle though.
Kevin Jewer
Old 10-30-2003, 09:13 AM
95_GSX's Avatar
Got AWD?
'08 Buell 1125R
89 probe gt turbo TURBO LEAKAGE sweetbiker Probe 0 03-08-2009 04:25 PM
size & type of the 4 bolts from the exhaust manifold to the turbo housing? eclipsed at 3am Engine, Transmission and Drivetrain 3 06-29-2006 07:06 PM
Exhaust Manifold to Turbo Housing size & type? eclipsed at 3am Engine, Transmission and Drivetrain 2 06-29-2006 12:22 PM
Cracked Turbo housing RX7-BOV RX-7 0 07-26-2004 05:24 PM
Turbo housing GWInquisitor14 Forced Induction 3 02-24-2004 02:14 PM
