Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 10-23-2003, 08:24 PM
micksdrunk micksdrunk is offline
adjust valves? on 96 kia sephia
im hearing a bad valve raddle what are the spec's on the adjustment?
Old 12-01-2003, 08:58 PM
benidorm benidorm is offline
Valves
How do you know it is the valves? I am also trying to troubleshoot a noise. Just wanted to see if it is similar. My 1996 Sephia makes noise that comes from the front of the car after accelerating to 35MPH and above. Sound sort of like a knocking or when a tire is loose. When you let off the gas the noise stops. It also gets louder the faster you go. Any ideas? Thank You.
Old 12-03-2005, 07:40 PM
nick bamberger nick bamberger is offline
Re: Valves
Will make a pinging sound when engine is under a load. Usally isn't constant, only heard under certain conditions.
Sounds like your problem is completely different.
Old 12-19-2005, 08:16 PM
KMG9185's Avatar
KMG9185 KMG9185 is offline
Send a message via AIM to KMG9185
Re: Re: Valves
Check your MAF...... and clean it lightly with a Q-tip dipped in rubbing alcohol.......
what happens is that maf gets contaminated and will give the computer a wrong reading of the wrong amont of air the engine is sucking in....causing the wrong timing advance and fuel mixture..... causing it to spark knock.... i think that is what you are describing.......if not check your knock sensor..
Kevin
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 02:28 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 06:22 PM
96 Kia Sephia main fuse donmega1833 Sephia 0 12-11-2003 12:17 PM
Fuel Filter 2000 Kia Sephia brdg826 Sephia 1 11-05-2003 01:16 PM
00' Kia sephia Vs 00' Yugo Nova 2strokebloke Car Comparisons 1 06-28-2003 09:32 PM
