Quick Question about installing an AMP
I am currently installing a Kenwood 1000 watt amp for my 2 Kenwood subwoofers. I have to run the power cord to the battery. Where can I drill a hole or find a hole through which I can take the wire from the inside of the car through the firewall to the battery?
Thanks |
Here is what I did in my stereo install: I ran the wire from the trunk along the bottom panels on the drivers side -all the way up to the front to the point where the wire is just above the top door hinge. Then I make a cut in the weatherstripping (wire still above the door hinge) to accomodate the wire. I used a hot glue gun to seal the slice I made in the weatherstrip. You will then be routing the wire so it will be going through that gap between the door frame & the front fender & then into the engine compartment. I found this to be the easiest way as opposed to drilling into the firewall because there is not much room to work with.
Re: Quick Question about installing an AMP
I ran my wires through the fender to the bottom of the car. THen drilled a hole under the back seats and then ran it to the trunk. Its easy and out of the way...
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines: POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
