Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-08-2001, 05:46 PM
ZeRo MaXiMa ZeRo MaXiMa is offline
Send a message via AIM to ZeRo MaXiMa
Question Lowerin' the Max?
I was looking around.. and saw that u can buy eibach springs for about 220$ ... Would this be the only modification to lower the car... or will it cost a lot more? what do i all need... and of course.. i won't be doin' this.. hopefully someone else can.. so how much money will this be?!?!
Hopefully under 500
cuz i want some rims added on too.. when i get it lowered...
Old 12-08-2001, 06:11 PM
Maximadave's Avatar
Maximadave Maximadave is offline
Send a message via Yahoo to Maximadave
Re: Lowerin' the Max?
Hopefully under 500
When you lower it you may want to look into some struts depending on how many miles you have. I actually had my stock struts with my Eibach springs on for 40K miles. I don't necessarily recommend it but 40K with no problems or abnormal tire wear. I spent $350.00 installed with a 4-wheel alignment (a must).
Maximadave:bonghitte
2002 Nissan Maxima SE
6-Speed Manual
Majestic Blue
Internet Manager @ Car Buy Choice, Inc.
Buy Your Next Car At Internet Wholesale
www.carbuychoice.com
(800) 290-0660
Old 12-08-2001, 10:12 PM
LATIN250 LATIN250 is offline
why pay someone to do it
Take your body to autozone and rent a spring compressor for $46.00 fee and once you return it you get your money back. What???? yes I did my rear shocks in my back yard for free. Does that help. It is not hard is time consuming thats all. You have the time do it. Youll save money to get your little rims. :smoka:
JR
Old 12-09-2001, 11:28 AM
1FastMax 1FastMax is offline
buy the ground control kit and u will never have to do an alignment again. trust me ive had them on my 97 max for a year on 18's and the tires are still new. good luck
Old 12-09-2001, 12:57 PM
Ravq Ravq is offline
If you are tight on $ you can go with just springs but if you wanna do it right the first time get shocks/struts and springs and do them all at one time. It'll save you from having to spend more time and money pulling out the suspension a second time. And whenever you change anything suspension related always get an alignment.
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
Old 12-09-2001, 08:33 PM
okie.. what should i get (shocks/struts) for my 97 gle max... and how much will it cost... i also wanted the eibach springs... and i'm no car mechanic.. so somebody will do this for me (laborer cost)... how much money will i spend to lower my car.. doin' everything right.. and makin' my sure doesn't mess up...
Thanx again!
Old 12-09-2001, 09:48 PM
Personally I'd recommend the KYB AGX shocks/struts because for the money you get adjustability.
http://www.cattman.com/kyb.html
But I've also heard that Koni's are pretty good. Price-wise the KYBs will run you about $400 shipped. Labor charges will run you anywhere from $240-$400. It's really very easy to do you might want to look into doing it yourself to save a you few bucks for other mods. Here are some instructions in case you're interested.
http://integra.vtec.net/geeser/megamax/springs.html
Old 12-09-2001, 10:26 PM
the kyb agx struts are for 380... does that include the shocks.. or do i have to get the shocks seperately.. same thing with the springs.. do i have to get the eibach springs which are for 220... i mean.. wow.. that's a lot of money... i have 700 right now.. and should be gettin' more.. i know that's not enuf.. i jus wanna lower my car.. the cheapest way without any problems in the future... i'm hopin' all i need is the struts for 380 and the springs for 220... so i have some money to save for rims...
Old 12-10-2001, 05:17 PM
$380 is the price for the whole set but it's another $20 for shipping = $400. Shocks and struts are relative terms. They mean the same thing. Here are there definitions:
Gas shocks-A type of shock absorber that's pressurized with nitrogen gas to reduce internal foaming and cavitation. Considered to be a premium grade shock, gas shocks are often used as original equipment on sports sedans and even mini-vans. A gas shock usually provides noticeably better ride control and flatter cornering. They're well worth considering if you're in need of replacement shocks.
Struts-A special kind of oversized shock absorber that's used as part of the vehicle's suspension. When used on the front suspension, it replaces the upper control arm and ball joint. Some struts have coil springs around them while others do not. Some struts have replaceable internal components that can be repaired by dropping in a new cartridge.
So you're looking at $400 (shipped) for the shocks/struts and $220 for the springs plus whatever it costs you to install them. If you do them yourself you'll be able to do it for $700 otherwise you'll need more $ to pay for installation.
One more thing depending upon the condition of your OEM shock boots you might have one more expense. If your OEM boots are still good then you can probably reuse them if they are worn or torn then I'd recommend you get some new ones. You can get them from Cattman.
Old 12-10-2001, 05:45 PM
Hey thanx for everything.... 380+220+100... exactly 700.. no ship and handling cuz i am local to owner of custommaxima.com, greg.. and 100 for installation... which is pretty good.. then i'll get the lights... which are 190 and 45... and then go get tinted ( 150 )... and hopefully find some cheap rims ... for 200... all of this will cost me 1300.. not bad.. but im gonna have to get more hours of work or i won't get it all done until spring.. which is what i plan.... thanx for all ur help... and i hope my black max will look like urs one day... one bad thing is that my maxima.. is 97 gle black AUTOMATIC.... still hope it will look great like urs... what % tint do u have.. and what "Exterior" mods did u make? :-)
I really like ur max!
Old 12-10-2001, 05:56 PM
Thanks for the compliments. As a matter of fact mine is a 96 auto. My tint is actually 20% mirror and a sheet of 20% limo behind it. Not exactly legal. As far as exterior mods I have the Stillin kit and SMX grill with the Stillen Type II spoiler, clear lenses and red/clear tailights. Oh and chrome Momo Status rollers. Good luck with your mods.
