Old 10-22-2003, 09:03 PM
triplerc triplerc is offline
Send a message via AIM to triplerc
okay guys Need help one big Question
okay, this is pissing me off. I bought a 88 V6 camaro in the summer, ran good minus the exhaust leak. I took the time to fix it with a new exhaust manifold gasket, now all is good with that. Now.. It starts up fine idles real nice, sounds good you know the usual well, after about 10 min of driving it down some streets or even idle for that long the oil guage starts to bounce up and down like it has to take a piss. Goes from 0 to 60 psi for about 5 minutes and then finally the pressure goes to 0 and then the check engine light comes on. It pisses me off to no other that i want to take a hammer and beat the living fuck out of the block. Im going to drop a 305 motor in it that came in another camaro that i got thats besides the point I want to get more run time out of the V6 before I put the V8 in.
Old 10-23-2003, 02:29 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: okay guys Need help one big Question
Double check your readings with an aftermarket gauge to see accurately what it's really reading. Could also be your oil pump is going out, acting up after things heat up.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 11-24-2003, 08:32 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
could be your pressure sensor, it is a part, and parts break. it should be screwed into the block above the oil filter. i dont think your oil pump is bad, because if youve been driving around with no oil pressure, you would be having some conciderably worse problems by this point. so i think your sensor is bad, kinda like, if your fuel sender goes, your guage may say that your tank is empty, even if your overflowing it at the pump, so you have a full tank (full oil pressure) but your guage says your in trouble. so i would replace the oil pressure sensor, its not very expencive, and not very hard to do.
Old 12-06-2003, 03:15 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
I had a bad oil pressure sensor and my check engine light didn't come on, but that would be the first thing to check. Not all problems are the same. If that fixes it great, if not...then it's time to check the oil pump. Hope you have a buddy to yell at while you do this, it sucks.
need help here big time!!!! bugsas99 Aurora 5 05-24-2005 04:33 AM
mustang guy needs help bigbob General 1 01-22-2005 01:01 PM
New guy needs help on cheap cars. Alastar Car Comparisons 6 08-07-2004 01:24 AM
guys need help fast... ebay header tech question. electronblue Engineering/ Technical 0 03-12-2004 03:03 PM
