Old 10-22-2003, 07:34 PM
CD Smalley CD Smalley is offline
Intermitent Astro Fuel pump
1992 Astro VIN Z
Drove it to work on Monday. Was there for about 15 minutes before I decided I didn't feel good and needed to head home. Went back to van and it wouldn't start. It would crank and crank. But wouldn't fire. I couldn't hear a buzz from the fuel pump either. Had it towed to the house. I had to take the battery out of the van and put that into another car so that I could get my wife and I to work.
Tonight I was able to put the battery back into the van. It fired right up! I could hear the fuel pump buzz and everything. After letting it idle for 20 minutes or so I shut it off. I tried immeditately to start it and got nothing again. Cranks but won't fire. I hear no buzzing from the fuel pump.
So I figure it's either the relay or the pump itself.
How should I go about testing the relay before I just throw a new pump into it???
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-23-2003, 06:27 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Intermitent Astro Fuel pump
Easiest way is to disconnect the connector at the tank and install a test light on the gray wire.
Have someone turn the key on..test light should come on and go off after 2 seconds...then spin the engine over..the light should come on and remain on until the key is turned off.
If the light comes on then you have tested the complete system up to that point and I would suspect a bad pump or connection
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-23-2003, 09:29 AM
RABarrett RABarrett is offline
Somethign to remember here si that the GM vehicles typically use an oil pressure switch in parallel with the relay. The computer operates the relay, the switch sends voltage to the pump directly. The computer also has a monitoring system which checks the relay's response to the computer's relay signal. If the relay does not respond, a code is set, indicating that the response circuit did not respond. If this code is set, I would suspect the relay, or its control system.
The problem here, I believe, is the pump itself. The oil pressure switch will send voltage to the pump directly, bypassing the relay. If the engine failed to start even when cranked sufficiently to create oil pressure, the problem is likely the pump itself, or the feed wire providing voltage to it. I would also check the pump ground, before replacing the pump. Ray
Old 10-23-2003, 09:00 PM
Checked the relay per the FSM. It seems fine. Tried to start again tonight and it still just cranks.
So right now I'm in the process of syphoning the gas out, nearly full tank BTW, and will start in taking things apart further tomorrow night. Hope to have it all done and running by mid day Saturday.
Thanks All!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-25-2003, 05:17 PM
Re: Re: Intermitent Astro Fuel pump
Well here it is 5:10PM CDT. The van is done. The tools are put away. But I'm still greasy, oily and smell like gas.
But it runs!!!
WooHoo!!
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
