Old 10-22-2003, 07:39 PM
pfnjr pfnjr is offline
Question EACV possible bad ?
Today I wanted to try again to get my idle smooth and keep the car from stalling with the air on, so I took the suggestions of you who have responded to myself and others like me with these problems. I adjusted the idle as specified in the pages of the manuals that you guys have posted from the service manual. NOTE **When I disconnected the EACV the idle didn't change up or down.** After resetting the ECU and reconnecting the EACV and restarting the car, the idle went up and down a few times before settling at about 850 rpm. If I turn the air on, the idle jumps to about 1250 rpm then slowly creeps down to just about a stall. It then starts to recover and the cycle begins again. Does this seem like the EACV or something else ?
Old 10-22-2003, 10:01 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: EACV possible bad ?
Kinda sounds like how mines was doing. I fixed mines by burping my cooling system (radiator). It idles fine now. It doesn't idle too high or to low anymore. The radiator was full but when I bleed the system there were alot of bubbles. Everyone told me to do the eacv, tps, fast idle valve and neither one of those were my problem.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 10-23-2003, 07:13 AM
redmanjd redmanjd is offline
it probably was i eacv because it works of your coolant lines and it probably had an air bubble in it and it came out when you bleed the system
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
heater problem... possibly bad coolant flow? chillware Grand Cherokee | Grand Cherokee SRT8 1 12-07-2004 01:15 PM
EACV gone bad? Shaguar47 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 12-02-2004 07:56 PM
possibly bad ecm? embflyr Sierra 1 06-11-2004 11:51 PM
Possible bad fuel pump mannella9 Taurus | Taurus Wagon 2 01-30-2004 08:09 PM
possible bad alternator? randomriot Engineering/ Technical 10 08-22-2003 01:01 PM
