85 Eldo fault codes
Hi, I am working on a 1985 Eldo with the HT4100 in it.
I can not get the car to pass the emissions test. I am getting a code 18 which I have read is no crank sensor? Do these engines have a crank sensor? If so, where is it located?
It seems to be running lean. It also seems kinda sluggish when accelerating. I have completed a complete tune-up (plugs, wires, cap, rotor, PCV valve, air filter, and replaced a couple of dryrotted vacuum lines. I also replaced the fuel filter. It has 12psi of fuel pressure.
Any suggestions on how to eliminate this code 18?
Thanks,
Jimmy
