Old 10-22-2003, 10:20 AM
P8ntb4llpr0 P8ntb4llpr0 is offline
Send a message via AIM to P8ntb4llpr0
23lbs of boost
Is it possible to run 23lbs of boost out of an aftermarket stage 3 turbo on any year eagle talon while still having the stock internals? Thanks!
Old 10-25-2003, 10:29 PM
boosting20psi boosting20psi is offline
answer
no it is not posible your car will start to cut out and that will do lots of damage you would proble be okay pushing 18psi that is as high as i would go with stock insides
Old 10-26-2003, 01:42 AM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Internals will easily take 23 PSI, if you have the correct supporting mods. Plus you can run 23 PSI on the stock 1G turbo
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 10-26-2003, 01:02 AM
slackingonthe1g slackingonthe1g is offline
stock 1g rods can support up to 450 hp. so im sure they will handle 23psi. although i would get a metal head gasket before i started uping the boost.
