Old 12-08-2001, 01:59 PM
97accordsy 97accordsy is offline
Send a message via AIM to 97accordsy
Camber kits
I was wondering if anyone would list web sites and or prices for camber kits (front and rear) for 97 honda accord ex. I found out today i need one when I had my car aligned. I find out how much tires plus is going to charge me for the camber kits on monday and i'm sure some of you out there know where i can get better prices. any feedback appreciated thanks
Scott
:bandit:
17''s on up thats all I ride
Old 12-08-2001, 04:09 PM
natcc99's Avatar
natcc99 natcc99 is offline
Re: Camber kits
you can probably find some on ebay.com
I really don't know any better places to get them.
however, i would like to send some useful information to you about camber kits.
becareful and do NOT get any extreme camber kits that correct up to 3 degrees of negative camber.
you will result in more problems because the camber kit will push out the upper control arms too far and will hit the fenders.
I got a camber kit that only adjust 1 degree and it is pretty much pushed out all the way. I have my upper control arm shaved down a little just to make the clearance inside my fenders.
How low is your car???
Do you know your measurements and how much of a camber problem you have???
Purehonda Moderator since March 2000
Purehonda Member since Feb 2000......and still counting
http://www.sounddomain.com/id/natcc99
Old 12-08-2001, 10:43 PM
illestaccord illestaccord is offline
where can u get ur upper control arm shaved??..cuz i'm going to drop my 90 accord...wit neuspeed race springs..and thats my biggest concern right now!!
The best street races in Ny....Hunts pt......The Fever!!!!
Old 12-08-2001, 11:10 PM
EliteAccordPH's Avatar
EliteAccordPH EliteAccordPH is offline
www.groupbuycenter.com has camber kits. It came out to be $250 for front and rear ones. Expensive yes...but it'll save you 10 times that in the long run.
Old 12-08-2001, 11:45 PM
natcc99's Avatar
my control arm was shaved by my alignment shop.
i actually paid big money for my alignement, i didn't go cheap on this important step.
my alignment was done by a professional shop that specialize in performance cars such as vipers, porsche, saleen, nsx, etc.
www.customalignment.com
the shaved was very little....probably only a few mm.
the important part was they knew what they were doing.
i went to a few other places just to find out some prices. a few places didn't do lowered cars. other plaecs didn't want my business because they only did normal stock cars and lowered cars wasn't their speciality.
Old 12-09-2001, 01:39 AM
JDM Accord 94 JDM Accord 94 is offline
Send a message via AIM to JDM Accord 94
i got my ingalls front kit for $165 installed at a local shop, and like natcc said i also got my control arm shaved for another 25 bucks at a shop that specialized on lowering vehicles.
www.TeamiCONZ.8K.com
Old 12-09-2001, 12:13 PM
natcc99, thanks for the feedback they showed me on their computer how much my front and rear were off by. I dont remember the degrees but my rear was the worse. I will find out exact degrees monday and then i'll let you know thanks again for the feedback.
Scott
Old 12-09-2001, 01:55 PM
natcc99's Avatar
sure...no problem....glad to help out
you said your rear has the worst camber?
that is odd because normally it's the front that has the worst camber when a car is lowered.
how low is your car?
Old 12-09-2001, 03:33 PM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
www.ingallseng.com
www.progressauto.com
www.specprod.com
Old 12-09-2001, 03:39 PM
when I got my progress kit, the guy who did it just did a washer job on the back. Turns out that my right front camber is now at 0, but my left front camber is -.3, they say this accounts for the car pulling to the left, hmmm, I'm so sure bout that
Old 12-09-2001, 04:08 PM
natcc99's Avatar
yeah, the rear is easy to fix....i used the same technic on my ride for the rear.
it's cheaper than getting an actual camber kit. for the rear.
i have a question for you DemonicAccord
0 on the right and -0.3 on the left?!?!?!?!?!
WHY????????????????
I wonder how that happened.
Old 12-09-2001, 04:13 PM
he said I may have bent a suspension component somwhere but he sure couldn't tell. The kit is on correctly, but its static, no adjustability, so its not like one side was adjusted wrong. I am going to get a kit from www.specprod.com that is adjustable, so I can get to zero, but right now its not a priority, just a little annoying on the highway. he said it wasn't common, but he'd seen it before. dunno
Old 12-09-2001, 04:42 PM
natcc99's Avatar
whoa...that is kinda scary. a bent component??!?!
has you car been in an accident before?
well, as long as it's safe to drive..it's cool
Old 12-09-2001, 05:51 PM
When I dropped my Accord 1.9" and 1.8" my rear camber was -1.1 and -1.2. My front was -0.8 and -0.9.
I got Ingalls camber kit in there and after putting on 17x7 rims I was able to correct the front to -0.3 and the rear -0.7.
Old 12-09-2001, 05:52 PM
My Accords pulls to the right:o And I'm sure its because it was sitting on a front right flat tire for like 6 months. Oh well I've gotten use to it.
