Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 10-22-2003, 12:42 AM
youngpup03 youngpup03 is offline
Angry 351c or 351m
allright i need help i admit i love chevy but i recently bought a 1970 ranchero with a 351c in it (8bolt valve covers) is there a simple way to tell if it is a 351m it is 2 barrel but 351c came with 2barrel as well as 4 barrel while the 351m only came with a 2barrel i need to know whats an easy way of identification on these 2 motors with out much dissassembely it has me seriously in aw hoping its not a 351m but that the mystery motor is a 351c plz reply or email me
[email protected]
Old 10-22-2003, 08:10 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
If it's the original engine, it's a 351 Cleveland.
The 351 Modified didn't come out until 1975 or so. Ford built that because they ran out of 351 Windsors, so they put 351W cranks in a 400 block and called it 351M.
Old 10-23-2003, 02:05 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 351c or 351m
Dan is right about it being a 351C if your truck is a 70. In 74 the Cleveland was discontinued, and the 351M was born, but only in full size passenger cars. (the M actually has no meaning other then an internal Ford reference to differentiate between the Windsor, and Cleveland). The 351M was not used in trucks till 77, and production of the block ended in 79, but the motor still popped up in Bronco's till 82.
But the reason Ford went with the 351M in not because they ran out of Windsor blocks. That is totally false!
The 351 Windsor engine was designed for higher RPM duty in small to midsize passenger cars. The 351M is actually a de-stroked 400 motor. The 351M was mainly designed to meet the newer tough emissions laws that the older (360/390/428) engines wouldn't be able to meet. The 351M was also designed as a low end torque motor to replace the above motors in passenger cars.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 11-21-2003, 11:54 PM
NavyMike NavyMike is offline
Re: 351c or 351m
This is great information but no one addressed his question, and , I also would like to know if there is an evident way of telling the difference from the outside appearance?
Old 12-04-2003, 07:28 PM
redneckdrfm redneckdrfm is offline
Re: Re: 351c or 351m
yea, u can the w has 5 bolt vavle covers and the radiator hose goes to the intake manifold.
the c has 8 bolt valve covers and the radiator hose doesnt to directly to the intake manifold.
Old 12-13-2003, 04:37 AM
ervinj ervinj is offline
w vs c
the valve cover bolt config. will tell you if the heads are c or w but the best way to tell is the engine ID no. on the back of the block, a small mirror on a swivel head might be helpful along with a can of brake cleaner.
ervinj
Old 12-16-2003, 01:30 PM
zxkevinxz zxkevinxz is offline
Re: 351c or 351m
i have a 351c torn down to the block on a stand. i have other projects but i'm cleaning this one up in my spare time. keep me posted on how yours turns out or any problems you have along the way.
1986 CJ-7 Renegade
Old 05-14-2004, 02:10 PM
n2racing n2racing is offline
Difference
The quickest way to tell the difference is the spacing between the top two bellhousing bolts. 351C are 5inches on center. The 351M is closer to 7inches.
I hope this helps. If you need any other help write me at [email protected]
Old 05-19-2004, 10:20 AM
Mercracer Mercracer is offline
Re: 351c or 351m
From the front of the engine, it is similar to telling the difference between a 302 and a 351W.
If the distributor mounting hole is even with the front mounting surface of the intake manifold, then you have a 351C. If the mounting hole is deeper into the block, then it is a 351M. The front inner corners of the cylinder heads are also raised above the distributor hole on the M vs the C.
Old 05-27-2004, 08:55 PM
who fan who fan is offline
Re: 351c or 351m
My experience with these motors is limited. My opinion is the 351C is a bad ass engine and 351M is a good boat anchor.
Old 08-24-2004, 04:08 PM
racercarsman racercarsman is offline
Re: 351c or 351m
i have a 351m in my 73 ford ranchero. the way to tell the difference between the two is that the 351m has a ridge that sticks out from the block on the front right next to the distributor
i myself dont see why every one is doggin the 351m it was mad to replace the 351c/w. the heads onthe 351m are the same as the 351c are the same as the 400/351m exept they have canted valves, wich means they are angled in the head to have greater flow. alsothe differences between the 351m and the 400m are the crank shaft and the pistons, its not a windsor crank in the 351m. the m-series is made for gobs of low end torq and power.
Old 08-29-2004, 03:53 AM
Paul Masley Paul Masley is offline
Re: 351c or 351m
I had a 351M in an 85 F150 4X4. Could not kill the thing. When truck was totaled in 1992 it had over 300K. The only thing replaced in the engine was the timing chain and gears. Bet you could have pulled a head and looked through and could see the crank. That truck got 22 mpg, regardless of it being empty or fully loaded, creeping in town or blasting down the interstate at 80. I would love to find another one.
Everybody is an idiot (including me) some of the time, but there are others that make a full time job out of it!!!!!
Old 11-09-2004, 12:42 PM
jerryred jerryred is offline
Re: 351c or 351m
there is a great web site for the reason for ID of 351 c m just punch in 351m or c if you find a place with bubba on it your there all you need to know
this site helped me sort out my 1977 351m problem
I bought a 1958 tudor 300 and the guy insested the engine was a 1971 torino but after looking at some of the ID numbers I knew something was wrong. after I found this the 351 site I now know that the motor is a 1977 or so F 150 but it is still a good project car and hope to have fun with it
Old 11-11-2004, 10:20 AM
Samw Samw is offline
Re: 351c or 351m
Actually, the "351m" and the "c" are both antique, boat anchors.
The late model 5.8L Windsor is a better engine.
It's a shame Ford discontinued the 5.8L in favor of the 4.6 and 5.4, overhead-cam wheezers.
A sorry bunch indeed. If Ford wanted an economical powerplant, they should have re-issued the flathead. True, it burned a lot of oil, but you can't have everything.
Old 11-18-2004, 10:37 PM
miverson332's Avatar
miverson332 miverson332 is offline
Re: 351c or 351m
??? Lost me.
Michael Iverson
"Just A Fat Kid With Broken $h!t!"
