Old 10-21-2003, 11:47 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Really need some help here...
I have a very odd problem...if i drive my car for a while and then turn it off and try to start it shortly after it either wont start...just cranks...or it will start and sounds like its only running on 2 cylinders..not sure if this is the case or its just missing real bad...but after just a few seconds its fine...it started with just the missing but now usually wont start...if i wait usually over an hour adn the car has cooled down its starts fine...
its not throwing any codes whatsoever..
Any Ideas?
Honda...An Army Of One
Old 10-22-2003, 08:58 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Try troubleshooting the igniter and main relay. Both feed power to vital parts of the ignition and fuel injection system. Good luck.
Old 10-22-2003, 10:26 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Don't bother with your ignitor, it's for sure your main relay.
Old 10-22-2003, 05:44 PM
Alan Wil Alan Wil is offline
Re: Really need some help here...
Any Ideas?
Main Relay, located to left of steering wheel under dash.
Marked:
Mitsuba
Relay Ass'y Main
RZ-0063
Japan 12v
PS: YOU CAN FIX IT BY RE_SOLDERING THE JOINTS IN ABOUT 5 MINUTES.
Alan
90 Honda Civic DX
Old 10-23-2003, 11:36 AM
plkelley's Avatar
the relay is pretty much brand new...and iv had main relay probs before...this is different...im starting to think its my injectors
Old 10-23-2003, 11:47 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
why do you think it's your injectors? what other symptoms?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-23-2003, 08:25 PM
plkelley's Avatar
well...the other day when it wouldnt start i held the gas down and it helped..still loped for a few but definetly helped get it started...
plus...if it was the main relay it wouldnt fire at all...if it was the ignitor it wouldnt fire on some cylinders and not others...and with either holding the gas down wouldnt help at all
i just cant figure out why if i let it cool down it starts but while warm it acts crazy...usually it would act funny during driving as well..so im thinking maybe an injector is sticking maybe...could be way off though..
please help
Old 10-23-2003, 09:25 PM
johnb16a2's Avatar
Do you have MPFI? Maybe your resistor box isn't working as good as it should and it's easy to check.
Old 10-24-2003, 12:02 AM
plkelley's Avatar
resistor box? where and what is it?
Old 10-24-2003, 06:41 AM
johnb16a2's Avatar
The resistor box is on the drivers side near the brake booster. It's aluminium with cooling fins. It lowers the power supplied to the injectors. I think it's supposed to spec out at 4-7 ohms.
You could also try a bottle of Techron by Chevron to try cleaning the injectors.
Old 10-24-2003, 08:45 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
It could still be an electrical issue, if it works OK cold. You could have some parts contacting when it is cold, and then the heat from it running creates a short in a wire somewhere...once it cools off and the metal parts condense, things connect again.
So, no real ideas, just some more things to think about...checking all electrical connections and resistor box stuff, etc.. is a good idea.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 10-24-2003, 10:10 AM
please help
You do try to keep a full tank of gas most of the time and you don't run the car low on fuel before you fill it up do you?
Look at all connections, try runing some injector cleaner.
Alan
90 Honda Civic DX
Old 10-24-2003, 11:12 AM
amy@af's Avatar
Re: Re: Really need some help here...
i really don't think it's the injectors. i've had many injector issues...while it did drive me mad, i also got to know them.
here is a really easy way to know if you have a faulty injector. start the car. pull 1 injector at a time and replug. when you unplug the car should bog down. if you unplug and nothing happens...you have found your bastid.
check around the injectors and the fuel pressure regulator for gas leaking out
and finally...you can take off your intake mani and clean it out if it looks dirty and clogged like
but seriously, if an injector is bad it has been my experience that the car will run like ass 24/7...not after it heats up. a bad or dirty injector is faulty, period.
when i had a bad head gasket it would run good until it heated up. but i doubt thats your problem. you would be running thru coolant and over heating as well.
Old 10-25-2003, 04:30 PM
plkelley's Avatar
well...whatever it was has finally kicked it...wont start at all now...just cranks all day...i can smee fuel so it has to be electrical...i checked the dizzy..looks ok..intact anyway....
im clueless..any ideas
Old 10-25-2003, 04:41 PM
Hybrid1990crx's Avatar
My crx had a similar problem awhile back. It wouldn't always start. It would take forever to start sometimes. It would die for no reason while driving, but start up again if I popped it. And it died all together after awhile. It ending up being the coil. But its going bad again. To fix the problem now....SWAP
