Old 10-21-2003, 08:38 PM
firefly386 firefly386 is offline
Send a message via AIM to firefly386
Exclamation probs with shifting into 1st & 2nd
I have a 96 eclipse that i have a problem shifting into 1st and 2nd the most 3-5th are not to bad but could be better....It feels like there something is in the way it does go in but is sticky.....also it had a rebuilt tran put in 6 month ago so i dont think it that.....What might be the prob and is there a way to fix it
ty
Old 10-21-2003, 09:16 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Theres a few thigns it could be.
1. Air in the hydralic system
2. Check the shifter cables connection on the tranny
3. Check the clutch pedal adjustment
4. Check the shifter to cable connection underneath the shifter itself
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 10-21-2003, 09:51 PM
DSM-Owner DSM-Owner is offline
check your cutch fluid. If its low put more in. There might be a leak in your clutch causing hard shifts and it will eventually drain all of it out. My best guess is get a new clutch master cylinder.... I put a new clutch master in my talon today and wow, what a difference....
95 eagle talon TSI AWD
Currently being rebuilt. Victim of CRANKWALK!
95 Eagle Talon ESI
18" konig rims, full custom exhaust, adjustable coil overs, rear strut bar, Cold Air Intake.
AIM = ATX eVo VII
Check Out My Car
Old 10-22-2003, 03:41 AM
kjewer1 kjewer1 is offline
AF - Advisor
The description of "it goes in but its sticky," and not grinding, leads me to believe its none of the usual problems as mentioned above, but binding calbles, or lack of lubrication at the shift/select levers. I would start there, unless it is actually grinding into gear as if the clutch system wasnt working properly, or the synchros were goingbad.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-22-2003, 10:00 AM
BlackBlur's Avatar
BlackBlur BlackBlur is offline
Banned
Send a message via AIM to BlackBlur
Yup my synchros are going bad...might wanna check those out because once they go out, you have to come to a complete stop to put it in ... well whatever gears out. Thats gonna suck if its and synchro except 1st , you learn not to use it.
Old 10-22-2003, 10:28 AM
Question Re: probs with shifting into 1st & 2nd
I checked for leak and saw none.
I look at the linkage in the car looks fine.
I had the cluch and synchn replaced 6 months ago with the trans.
Do hey go out that quick??
Also when i move it back and forth a few time it goes in to 1st. once it is in 1st or 2nd and i have the cluch push in it shift fine. I can move it to 1st and 2nd and there no stickin as long as i have the cluch in, After i drive i go to do it over. longer i drive the worse it gets.
I took it for a ride and when im down shifting and go to 2nd, I pull it to 2nd and in stead of force it i coasted and when i get down to 15mph or lower it when in.. also im not down shifting fom 30 or some thing like that
Hope this more info help you guy
Old 10-22-2003, 01:06 PM
whoa, 6 months ago. It should be smooth if it was replaced. I would take it back to the shop of where you got it from and tell them. Either they messed up somehow or you just dont know how to drive a standard very well . The leak in the clutch master cylinder is hard to find.... cause it really sounds like there isnt enough lubrication when you say "the more i drive, the worse it gets". Just like an engine, no oil, no go
95 Eagle Talon ESI
AIM = ATX eVo VII
Check Out My Car
Old 10-22-2003, 03:20 PM
as to me know how to dive a stick, I have to troubles, that all i drive. But as to fixing them i dont know everything. Auto iv done.
I went and bout soung redline fulid and going to chang that ans see what happen will let you guys know.
As for the master cyclder if this dont help I will check and see if there is any thng wrong with it.
Old 10-22-2003, 03:21 PM
as to me knowing how to dive a stick, I have no troubles , that all i drive. But as to fixing them i dont know everything. Auto iv done.
Old 10-22-2003, 03:55 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
you might have bent one of the fingers on your pressure plate. i had the same symptoms and a bent finger turned into a broke finger and lodged itself to where i couldn't shift into 1st or 2nd at all. this happened 2 minutes after i left my tune shop where i just paid for my new clutch and was bringing the car back the next day. try doing a u-turn with only 3rd... lol ...
also try giving the engine a rev right before you try to put it in gear. ie: depress clutch, shift out of 3rd, qiuck rev, then try putting it in gear.
also, for all of you unlucky enough to have been through it...could this be a sign of crankwalk? or is that for 97 and up?
Old 10-22-2003, 05:07 PM
crankwalk is mostly for the 95-99 cars. I just figured his car was a non turbo since he never said in his posts ..... and no i don't think its a sign of cranmkwalk
95 Eagle Talon ESI
AIM = ATX eVo VII
Check Out My Car
Old 10-23-2003, 01:16 PM
AF - Advisor
I had to read the last description 3 or 4 times, and I'm still not positive I understand it, but it sounds like it is in fact synchros. If it was clutch related, its almost always in all gears, not specific ones. Who rebuilt the tranny? Also, if the shift calbes are not adjusted properly (2g is non adjustable, but the brackets at the trans can become bent) it can wear the synchros prematurely. A clutch that grabs too close to the floor can do that as well. Then once they wear, the issue with the original bad adjustment will become very apparent It could also have been a shyte rebuild, or one of those hack shops that replace the axle seals in a junkyard tranny of unknown condition and call it a "rebuilt" tranny . One last option, and the cheapest to remedy, is the oil. DSM turbo trannys are very particular about what oil they like. 95% of poeple find the a tranny with old or bad synchros will shift much nicer with BG synchroshift. Even on a new tranny it can make a noticeable difference. I would start there, since its the easier thing to do.
Kevin Jewer
Old 10-23-2003, 06:38 PM
can you clarify about the tranny juice? BG synchroshift?
Old 10-23-2003, 07:58 PM
Talon007's Avatar
Re: Re: probs with shifting into 1st & 2nd
B-G s-y-n-c-r-o-s-h-i-f-t
Chris Clark
www.Talon007.com
Old 10-25-2003, 02:36 PM
duckydsp's Avatar
duckydsp duckydsp is offline
I had that problem but found out my crappy shifter was just bent. Sometimes it's just an easy problem like that. I dove right in and assumed it was a major problem and overlooked the easy and the obvious problems which were right under my nose. Did you see if your shifter is beat up?
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
