Old 10-21-2003, 06:31 PM
Mike K Mike K is offline
Send a message via AIM to Mike K
Coolant Leaking Problem
Hi
I have a problem with the Cavalier, again. It's a 1993 2.2L It's leaking coolant again. I've replaced both radiator hoses. I've triple checked the connections at the hose ends and there doesn't seem to be anything comeing from there. What else should I check? Thanks
Old 10-21-2003, 08:19 PM
shhtbyrd shhtbyrd is offline
your problem maybe your are leaking from your heater core or it's hoses. i had same prob. then noticed it leaking down my firewall
Old 10-22-2003, 04:41 PM
Sniper0860 Sniper0860 is offline
I had a pretty bad coolant leak in my cavy, and the thing that caused the problem was the radiator cap. It wasn't maintaining the proper pressure and that caused it to boil over, you might want to check that.
Old 10-25-2003, 08:14 AM
EyeCon7 EyeCon7 is offline
Re: Coolant Leaking Problem
Hey;
I have a '92, 2.2L, and just had to replace the rad. The hoses were just fine, but the rad was pretty coroded. It happens. You might want to pop the hood, and heat up your engine and see if you can find any steam coming off the rad. Then, you'll know you have a leak throughout the rad, and that you'll need to change it.
I just bought a rad for $140.00, new. It's not that big of a job. I'm a chick and managed. I'm sure you can too
Old 10-25-2003, 03:42 PM
Re: Re: Coolant Leaking Problem
Originally Posted by EyeCon7
Hey;
It was the water pump. I actually did what you said(but before I read it).
Old 10-26-2003, 07:09 AM
Re: Re: Re: Coolant Leaking Problem
Glad you figured it out! I'm still messing around with my car, trying to figure out why the engine light is still coming on. It's either some loose wiring, or the stupid thing needs to be reset.
