Old 10-21-2003, 05:42 PM
1996talonesi 1996talonesi is offline
wont start!! help please
hey everybody.... well i have a 1996 eagle talon esi and i was driving around last night and i went to the gas station too fill up then when i tried starting my car it just click so i figured the battery was dead... had my dad come jump start me... worked fine. got home tried starting it agian no click at all completely dead. so i tried charging it but everytime i put the charger on,,, it would freak out and start sparking like i was touching a positve and negitive directly together... so any way today i got a new battery hooked it up and all it will do now is turn over... doesnt sound like it is getting any gas.... did the computer freak out or sumthing??? thanks any help would be greatly appreciated
Old 10-21-2003, 06:39 PM
DSM-Owner DSM-Owner is offline
what do you mean "it will turn over"??
95 eagle talon TSI AWD
Currently being rebuilt. Victim of CRANKWALK!
95 Eagle Talon ESI
18" konig rims, full custom exhaust, adjustable coil overs, rear strut bar, Cold Air Intake.
AIM = ATX eVo VII
Check Out My Car
Old 10-21-2003, 07:09 PM
when i say it will turn over i mean it sounds like it would if i where out of gas.... i can feel the car shake cuz the engine is trying to start but just wont.... sucks.... thanks
Old 10-21-2003, 07:15 PM
how many miles on the car?? also check your spark plugs to make sure they are producing spark to the engine
95 Eagle Talon ESI
AIM = ATX eVo VII
Check Out My Car
Old 10-21-2003, 09:07 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Four things to make an engine start:
1. Fuel
2. Spark
3. Air
4. Compression
Find out which one is missing.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 10-23-2003, 01:59 PM
96talontsi 96talontsi is offline
have you tried push starting it? just a suggestion
Old 10-23-2003, 02:04 PM
kjewer1 kjewer1 is offline
AF - Advisor
Like talon said, check for fuel and spark. Also check the fuse for the ECU.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-23-2003, 02:19 PM
where is the fuse for my ecu??? thanks
Old 10-23-2003, 02:23 PM
AF - Advisor
I Wish I knew more about the NT DSMs... But its going to be under the hood in a fuse box. It will potentially be called MPI, Ignition, ECU, Engine, or Motor. Those are some of the common names anyway.
Kevin Jewer
Old 10-23-2003, 02:26 PM
hey sorry about the confusion this is 96talontsi, not 1996talonesi lol.... i was just curious about where it was in mine.... i have no problems (except being curious)
Old 10-23-2003, 03:10 PM
AF - Advisor
LOL On the turbo cars it is in the fuse box by the filter. I believe it is "motor" In a 1g, its the MPI fuse on the block hanging off the positive terminal.
Kevin Jewer
Old 10-23-2003, 07:37 PM
Talon007's Avatar
YA 1G T/NT same shit
Chris Clark
www.Talon007.com
Old 10-25-2003, 09:07 PM
boosting20psi boosting20psi is offline
you out my want to try your cooling temp senser my went out and the same thing was haping so llok into it
Old 10-26-2003, 12:17 AM
biggd29 biggd29 is offline
i have this same problem with my 97 eclipse. i've actually had this problem for over 2 years. i'm not sure what causes the problem. but is defineity fuel related.
i've found that if i put in a high octane gas and some fuel injector cleaner, it seems to fix the problem, at least for a few months. i've found that problems seems to ocasionaly come back.
another fix i've come accross is to disconect and reconect the connecters that go into the module. if you do that, i'm almost certian that your car will start.
