Go Back   Automotive Forums Car Chat > Mitsubishi > Lancer
Old 10-21-2003, 02:15 PM
CB3A63 CB3A63 is offline
Send a message via Yahoo to CB3A63
Exclamation Installed an Apexi SAFC nid help!!!
Guys,
i nid help badly.... i recently installed a Apexi Safc......
i followed the instruction on the manual... i was able to have it running and everything is quite running perfectly.. except for one...
its reading half of wat is suppose to be on display on my tach.....if my gauge is telling me m reving up to 2000 rpm, my AFC displays only 1000 what to do guys??? is there something i missed???
my car is a lancer 1993 with a transplanted 4g63 N/T eci-multi 1st gen engine....
Old 10-21-2003, 06:26 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Installed an Apexi SAFC nid help!!!
Somewhere there will be the ablity to adjust how many cylinders the AFC thinks your car has.
At the moment its calculating your revs based on the ignition timing of an 8 cylinder.
Old 10-21-2003, 06:44 PM
even if i set it to 4 cylinders???
many thanks for you input....
guys.. please help me... more inputs please.....
thanks for your time...
Old 10-21-2003, 06:52 PM
Moppie's Avatar
Master Connector
You need to set it to 4cyl, then it should show the correct RPM.
If it still dosnt then double check you have it hooked up correctly.
Old 10-21-2003, 06:59 PM
much appreciated bro...
i already set it to 4 cylinders but d problem still persisted...
do you think its with the wiring???? but how come it is still able to read the revolutions??? although its just half of the real thing but still it was able to read???
Old 02-01-2004, 01:14 PM
Mr. D Mr. D is offline
I have a B2200 mazda with this computer in it and now I have lost the manual for it. Do you know who I could order one from?
Mr. D
