Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-21-2003, 02:07 PM
dkkgg dkkgg is offline
Question 1997 GP GT - ABS Lights always on
Is there a way to turn off the ABS warning light, Trac light and the tire pressure light other than replacing the ABS Mod?
Old 10-21-2003, 08:55 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: 1997 GP GT - ABS Lights always on
Have you gone somewhere like the dealer or Autozone and had the codes pulled? If you have..and it is the ABS module, then why not replace it? I wouldn't skimp when it comes to brakes....they're what keeps you on the road.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 10-25-2003, 07:07 PM
dubbster59 dubbster59 is offline
Did you have a diagnostic run on this? Same thing is happening on my 98, but nothing showed up on the diognostic. Have you tried using your cruse control? mine will not function with the TRAC and ABS lights on.
Old 07-10-2004, 08:43 PM
rgk01 rgk01 is offline
Same thing happened twice on my 97 GP. Both times wheel sensors went bad. You will need to replace the entire hub as the sensors are not repairable.
Old 07-12-2004, 09:23 AM
carnutcass's Avatar
carnutcass carnutcass is offline
Have you checked to see if the fuse that protects the ABS and TCS systems hasn't blown? I'm not sure about the '97 but the '02 has a 10A fuse under the hood for the ABS and TCS. It also protects the MagnaSteer® system. Does your steering feel unusually heavy?
Old 07-14-2004, 06:49 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Look under the dash. There's a button that you hold in for about 10 sec. Also works on "low air" light.
Old 07-17-2004, 02:27 AM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
Clean the ABS Speed sensors at each wheel with a air compressor, i was posted some thread about it... first do this, you can save a lot of $$$$ money...
Hope this helps
RED 1999 Grand Am GT - RAM AIR V6 H.O., 4drs, sunroof, and more!
Old 10-24-2004, 10:07 PM
StvnRowe StvnRowe is offline
I had the same problem on my '00 SE. Took it to the mechanic, and he tested it w/ the computer and he didnt have any codes come up. He then tested each wheel individually and realized that my driver's side front wheel wasn't putting out any code at all. So i took the car to the dealer and they said they would have to replace the wheel hub. Unfortunetely, they replaced it with a bad weel hub and had to replace the hub yet again. But once they fixed the hub, the lights turned off. Hope that helps.
Old 10-01-2006, 07:33 AM
Just to let you know.....The issue was the wire harness had been rubbed through and broke the connection. I repaired and I am good.
Closed Thread
