Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-08-2001, 10:21 AM
sirmaxalot sirmaxalot is offline
matching clearance lights with cool blues
I just bought a pair of sylvannia cool blue headlight bulbs for my '98 GLE but noticed that the clearance lights next to the headlights look yellowish next to them. can anyone suggest a clearance light bulb brand that would complement the cool blues nicely?
Old 12-08-2001, 10:38 AM
NJMAXSELTD NJMAXSELTD is offline
PIAA
I'm running the PIAA's in the corners. Make sure you make the change in the clearance lights to light up the 27Watt filiment. The socket and bulb have 2 notches so the bulb only goes in one way. If you cut the upper notch off the bulb with a pair of nail clippers, turn it 180 deg so the lower notch on the bulb goes into the upper notch slot in the socket, the high watt element will light up in the corners. Makes them nice and bright and should match your headlights perfectly.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 12-10-2001, 09:27 AM
MegaMax MegaMax is offline
Send a message via AIM to MegaMax
http://www.zupsbasement.com:880/corner.htm
or
http://www.zupsbasement.com/corner.htm
Not sure what link will work.. But look at my lights...
MegaMax
  • Suspension:
    Ground Control CoilOvers, $tillen FSTB, RSTB, Addco RSB
  • Lighting:
    Clear Signals, ALL bulbs Hyper White, Rewired Signals, Brighter Corner Light Mod, Rewired Fog lights, Blue Neon Headlights, Hyper White Washer Nozzles, Blue Under Car Neon, Blue Neon Under Dash, Custom wired Tail Lights
  • Cosmetic:
    Blue Break Calipers, ALL Windows Fully Tinted, NisMO badge on rear
  • Performance:
    TB Coolant Bypass, Cattman Jet-Hot Y-Pipe, High Flow Cat, Greddy Catback, $tillen HAI, Unothodox Racing Underdrive Pulley
  • Other:
    Optima Battery Relocated to Trunk,NGK Platinum Plugs, Synthetic Motor Oil (Every 5K), Synthetic Trans Fluid, 93 Octane Fuel ONLY.
  • Best E/T:
    15.4 with just the $tillen HAI 2 years ago… Now, go to the Track to find out..!
Dre's Corner
www.Maxima.Org
www.superstallions.com
www.f150online.com
Old 12-10-2001, 09:06 PM
thanks for the help, i'll try messing around with the wiring and see how i like it.
Old 12-12-2001, 10:09 AM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
blacklight !!!
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 12-17-2001, 11:19 AM
Question
i tore off the wrong nub on the left clearance bulb (doh!) so i couldn't run it at the higher wattage. so i tore off the nub closest to the bulb on the right bulb, then inserted the bulb 180 degrees. when i turned the switch, the left one lit up at the regular 5 watt, but the right one i turned 180 didn't light up at all. i tried reinserting several times but it wouldn't work so i put it back in the original way and it light up at 5 watt again. what am i doing wrong?? is it because it will only light up 27 watt if both left and right bulbs are switched 180?? i obviously didn't pay attention in physics or i would be so confused
Old 12-17-2001, 11:24 AM
I will look at My site for the Pics and do a Lil Write up on this for you....
Give me a day or so....
Andre S.
I Will post Pics and such....
MegaMax
  • Suspension:
  • Lighting:
  • Cosmetic:
  • Performance:
  • Other:
  • Best E/T:
Dre's Corner
www.Maxima.Org
www.f150online.com
Old 12-18-2001, 05:08 PM
thanks megamax i really appreciate it. btw i love the stock look of your max, i wish i could find aftermarket rims that look as simple yet sporty as the stock se rims
Old 12-18-2001, 06:15 PM
Stock look..?
Let's see...
All Lenses are Cleared in the Front... All Bulbs were replaced... All Lights in front are re-wired...(Fogs, Signals, Clearance, Headlight...) All windows Fully Tinted (Even Windshield)... Tail lights Re-wired... NisMO Badge on rear... Neon Here and there...
Greddy Cat-back... Cattman Y-Pipe... Stillen HAI...
Unothodox Racing UDP...TB Bypass... Stillen FSTB... RSTB... Addco RSB...Ground Controll Coil overs (Slammed)...
:flash: Stock Paint.... Stock Rims... :flash:
I see what you mean
MegaMax
  • Suspension:
  • Lighting:
  • Cosmetic:
  • Performance:
  • Other:
  • Best E/T:
Dre's Corner
www.Maxima.Org
www.f150online.com
Old 12-18-2001, 09:24 PM
you're right man, i didn't mean that way. lets see, how should i put it... i think that nissan should've produced a tuner version of the max that looks like you'rs on the outside (not stock looking but not loud either)
Old 12-20-2001, 10:16 AM
I Re-did the Sig to show how "Stock" the car is...
Anyway Lastnight I looked and couldn't find the Pic's I took i will look again as they may of a Dif web server i have... i'll let ya know of just re do the Pics
Andre
MegaMax
  • Suspension:
  • Lighting:
  • Cosmetic:
  • Performance:
  • Other:
  • Best E/T:
Dre's Corner
www.Maxima.Org
www.f150online.com
Re: problems with 93 Crown Vic instrument panel and clearance lights NC92CrownVic Crown Victoria 1 09-30-2006 03:41 PM
ground clearance problems with a Z06? Doucette Corvette 13 01-28-2003 09:13 PM
which one? sylvania xtravision or cool blue. sebaxx Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 11-06-2002 01:23 AM
Park lights/clearance light G20t Associate Cosmetics 3 06-03-2002 12:33 PM
Cool blue headlights shane Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 09-04-2001 02:22 PM
