Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-21-2003, 11:16 AM
steve_aero steve_aero is offline
Angry Sunroof Noise
I have a 2003 SR5 V8. There is a very annoying noise that comes out from the sunroof. I took it to the dealer and they were not able to fix it. According to them, Toyota knows about this problem and is coming out with a part (a tube of some kind); but not sure when!! Any body experiencing similar problem?
Also, my wife mentions there is a metal like noise coming from somewhere in the back. She can hear it when she is sitting in the rear seat but I can not hear it from the front.
Beside these noise problem, I love the vehicle.
Please share if you have similar problems. Thanks.
Old 10-21-2003, 12:54 PM
MrTom MrTom is offline
Have your dealer show you
Technical Service Bulletin
NV003-03 ,2003-06-11
NOISE, VIBRATION & HARSHNESS HEADLINER RATTLES (REVISED)
Tom
Old 10-21-2003, 03:16 PM
BlackBerry BlackBerry is offline
I have experienced the exact problem with the noise in the back
turns out it is the rear seat latch. It sweaks
the fix is to apply some White Lithium Grease to the latch, this worked for me. I have a 2003 SR5 V8 Sport
this grease can be bought from any Toyota dealership
Don't waste your time bringing it in like I did, chances are they will not find it.
Old 11-06-2003, 12:36 PM
Thumbs down
Regarding the sunroof noise, still no fix. I contacted the dealer again, they said they can not do anything until toyota comes up with that new Tube/part. They have no idea how long it will take either.....meanwhile I am driving with that annoying noise everyday. It is just sad that it is happening in a brand new vehicle that costs over $30K. Anybody have same problem? Were the dealer to fix this without waiting for that part? Thanks in advance!
Old 12-20-2003, 05:38 PM
influx99 influx99 is offline
Angry Re: Sunroof Noise (rattle)
Just bought a '03 4Runner SR5 v8 used with 3300 miles on it (demo). When I test drove it, I noticed the rattle. Told them I wanted the rattle fix before I bought the truck. Went back to check it out and the noise was gone. The salesperson said that a screw was loose in the sunroof and it had been fixed (but I'm not so sure that was the fix). OK, no problem. Bought the truck and drove 50 miles home. By the time I was home the rattle had started again.
My particular rattle sounds like a loose screw. It's metal-on-metal rattle, and it's not particularly loud, but it is very annoying.
I tightened all the visible screws. None were loose.
The rattle is not caused by the wind. It's caused by vibration, because it rattles even when idle.
When I push up on the glass of the sunroof, the rattle stops. So I could drive around with one arm on the steering wheel and one on the sunroof, right?
I haven't contacted the dealer yet, but will let you know what I find out. I want to know what they really did to stop the rattle the 1st time.
Old 12-22-2003, 10:11 PM
2SLOW2FURIOUS 2SLOW2FURIOUS is offline
it should be under warranty . I would leave it at the dealer and get a loaner until they fix it.
Old 12-30-2003, 12:55 PM
Re: Sunroof Noise
Here is the rundown,
1. First time I took it, they told me it was fixed and it never was. They told me they put a extra foam/pad. As soon as I drove off the parking lot the noise came back. I took it right back, then the manager admits that it is a known problem and toyota is coming up with the part but not sure when. I basically had to wait for that.
2. Got a call back in about 3 weeks. Took it in. When I got there, the service manager realized that one of the part still had not arrived. Sent me back home.
3. Got another call in about 2 -3 weeks and I took it in. It was finally fixed.
So it took about 1 and 1/2 months and few trips to the dealer to get it finally fixed. Toyota has a service bulletin out (refer to the postings above), the dealer basically replaced some parts with new parts.
Old 01-29-2004, 07:31 PM
Re: Re: Sunroof Noise
Steve,
Not to be a pain, but I was wondering if you could expand just a little on your fix. I got to a point back in Dec. where I had closed the sunroof and the noise stopped. Being in New Englad, there's no reason to open it again until May. Anyway, I'm incredibly busy now and haven't been to the dealership. I know when I open and close the sunroof again, the rattle will start. It must now be in some kind of perfect position to not rattle.
I want to be armed with all the info possible when I get the truck to the dealer. I know now that the noise is not a screw... it's the glass or surrounding metal rattling against the headliner. That's why it stops when pressure is applied to it. Does this sound like your problem? Was the fix the same one as known in the technical bulletin?
Thanks for the help
Old 01-30-2004, 07:22 AM
G5gyrl G5gyrl is offline
Re: Sunroof Noise
I just bought a 2004 with a sunroof, and so far no noises. Does the rattle start over time or from the beginning?
Old 01-30-2004, 09:50 AM
I don't know the answer to that one because I bought mine with 3300 miles on it. I'm glad it happened so early, though, because it's covered by warranty. I'd open and close your sunroof pretty often to see if you can get it to make noise. I also have a 2003, so I don't know if they fixed the problem for 2004 or not.
Old 01-30-2004, 10:36 AM
Re: Sunroof Noise
It's been opened & shut a few times, so far so good. The one I test drove first didn't seem to rattle either, and I'm sure that had more miles on it. Mine has 158, hee hee.
Old 02-02-2004, 08:47 AM
Re: Re: Re: Sunroof Noise
Yes the fix was the same one listed on the technical bulletin. The noise was due to some metal/wiring stuff AND I think they came with a new part that is like a foam tube or something that will be wrapped around the wiring.
Also I have a couple of other noise problems.
-There is a noise coming from from back of my rear seat, which is not too loud from the front seats but you can hear it from the rear seat distinctly. I read somewhere that it is just the latch on the rear seat and could be fixed by putting some kind of lubricant.
-Another one is kinda strange. Do you know the sound of that latch or locking mechanism when you close your rear door? (it is about 2 second long too). Well when I am driving, I get that sound randomly. I have not been able to show it to the dealer because it happens randomly. Anyway, let me know if these problems seems familiar.
Originally Posted by influx99
Steve,
Thanks for the help
Old 02-02-2004, 11:57 AM
Re: Sunroof Noise
"Yes the fix was the same one listed on the technical bulletin. The noise was due to some metal/wiring stuff AND I think they came with a new part that is like a foam tube or something that will be wrapped around the wiring."
Ah, so maybe they fixed it for the 2004, I sure hope so!
Old 02-06-2004, 11:17 PM
LTC9024 LTC9024 is offline
Re: Sunroof Noise
I have had the same noise for several months. I hade it "fixed" two months ago to no avail. The dealership "fixed" it again a couple of days ago, again using the TSB as a guideline and using the parts which includes some grease of some kind. They got rid of the noise when the vehicle was idling but it has now returned when I go over bumps. I will be getting a hold of the dealer who said if it returned he would order a whole new unit(over $2000 Can$) though he knew Toyota would not be a happy camper. I will be calling him next week.
Old 02-11-2004, 02:47 AM
ToyotaTech ToyotaTech is offline
Re: Sunroof Noise
I just fixed a 2004 with the new tsb that Toyota sent to us all is well now!
