Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-21-2003, 09:14 AM
Anarhcy1505 Anarhcy1505 is offline
Unhappy !!!!!Radio Removal!!!!!!
Hey, I have a 97 Oldsmobile Cutlass Supreme, dose anybody have any idea how to remove the radio so I can put in a Cd player in it, also does any body know where I can aftermarket harness for the cd player.
Thanks
Old 10-21-2003, 02:15 PM
bgchrs2004 bgchrs2004 is offline
if its kinda like my 94 then you just remove the dash trim by removing the screws then i had to kinda "wiggle" it out a bit lol. maybe it was a harder than a wiggle but o well.... when you get it off you can just pull of the headlight switch (it snaps into place) then put it off to the side... then you just remove the to radio screws and pull it out.... unplug the wiring in the back and remove the radio from the car.... hope this helps
Old 06-19-2006, 06:39 PM
Dusty Rose Dusty Rose is offline
Re: !!!!!Radio Removal!!!!!!
bqcjrs2004 wrote: "if its kinda like my 94 then you just remove the dash trim by removing the screws then i had to kinda "wiggle" it out a bit lol. maybe it was a harder than a wiggle but o well.... when you get it off you can just pull of the headlight switch (it snaps into place) then put it off to the side... then you just remove the to radio screws and pull it out.... unplug the wiring in the back and remove the radio from the car.... hope this helps."
Would it be the same procedure for an '89 Olds 98? We want to put the radio in an '88 Buick Park Avenue (coporate twins/same radio).
Thanks,
Dusty Rose
Old 07-07-2006, 06:25 PM
cutlassthatstalls cutlassthatstalls is offline
Okay guys you'll need a harness for your hookups. They cost roughly $5-$10 and there specific to the make of your vehicle. You plug the wireplugs that went into your stereo into the harness and on the other side of the harness are colour coated wires with the diagram. Just connect these to the cd deck (eg. power antenna->power antenna,Groud->Ground,Duh!!) and your good to go. Oh and i forgot you will probably need a mounting bracket to fit the cd player snugly in place. You can get these at any parts store.
Hope it helps.
Old 07-07-2006, 07:52 PM
Dobbskel Dobbskel is offline
Send a message via AIM to Dobbskel Send a message via Yahoo to Dobbskel
parts are cheap at Wal-Mart
