Old 10-20-2003, 07:58 PM
badassaccordriver's Avatar
badassaccordriver badassaccordriver is offline
Send a message via AIM to badassaccordriver
license plate lights
i was wondering if it would be too hard to like bridge a connection from the 2 lights that illuminate my plate, and run them to like a switch inside the car so i can turn them off when i press the switch. i know the plate lights run from the trunk to the engine bay....i think. where would be the best place to bridge the connection? i have a 95 accord by the way; and if this doesnt make any sense, then just tell me to clarify.
Old 10-20-2003, 08:28 PM
esp's Avatar
esp esp is offline
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
Re: license plate lights
its possible, just wire in a switch in between the wiring and the lights, it should work, no different then wiring any other switch in
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
Old 10-20-2003, 08:49 PM
do you know if the plate lights run inside the car, or do they run on the inside of the exterior panels?
Old 10-20-2003, 09:01 PM
esp's Avatar
esp esp is offline
um i am not positive, but there has to be someplace where the wires are exposed, find a wiring diagram for an accord or something to find the color wire it is if there is more then one wire there.
5/29/03
www.fotki.com/esp
Old 10-21-2003, 08:10 AM
yeah i found the wires, they ran under the door sill, then into the steering column. should be easy now, thanks for teh help.
Old 10-21-2003, 10:39 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
There should be a fuse for them under your dash panel. Just make a switch to bridge the connection there like this so you don't have to cut any wires:
The fuse may be for tail lights AND license plate lights. If so, you'll have to actually cut into the wires coming off the lights.
Old 10-21-2003, 11:24 AM
esp's Avatar
esp esp is offline
Re: Re: license plate lights
best picture eva
5/29/03
www.fotki.com/esp
Old 10-21-2003, 12:47 PM
Ricochet's Avatar
Banned
Re: Re: Re: license plate lights
MS Paint ownz
especially when bored at work..
Old 10-21-2003, 04:11 PM
the fuse box under the dash was like the first place i checked for teh wires, but i didnt see the cluster of wires there, they run from the rear quarter panel, then down into the door like under the door sill and carpet. but i lose them around the hood release switch, do you think they go up inside to the steering column? thanks for the help.....and the diagram
Old 10-21-2003, 06:41 PM
Ricochet's Avatar
Banned
You're not looking for wires under the dash, you're looking for a fuse to put your own wires on. It was just a rough diagram, you can make the wires as long as you want and install the switch wherever you want.
If you're talking about the wires running from the lights into the fusebox, I have no idea where they are. If your fuse is for tail lights and plate lights, then yeah you'll have to find those and splice into them. I'm sure a google search will bring up some more helpful diagrams.
No Tail Lights, No License Plate Lights-Help! dajulius Aerostar 2 08-21-2007 07:16 PM
License plate light, after market that lights up all around plate. stcoughlin Grand Prix 5 08-02-2006 12:38 AM
1991 Accord EX License Plate Light Melt Accord/TSX/Accord Hybrid 1 01-07-2003 08:08 PM
neon license plate lights Tiffany196 Accord/TSX/Accord Hybrid 1 11-19-2002 10:28 PM
