Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-20-2003, 07:26 PM
hmooblis hmooblis is offline
v-tec
why do people take out the vtec system for high hp cars? nissan does the same with their vvti(vtec like) system.
Old 10-20-2003, 09:17 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Isn't it Toyota that has the VVT-i system and not Nissan?
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 10-20-2003, 09:27 PM
nissan has a similar system, but back to the question
Old 10-20-2003, 09:30 PM
Maybe its so they can have lower compression ratios...i have no clue, i am just taking a guess. Anyone who actually knows what their talkin about wanna add in?
bwhahahaha
Old 10-20-2003, 09:40 PM
i think it has to do with the cam profile and lift but i don't know exactly what.
Old 10-20-2003, 09:52 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
It is because they have cams that only have the vtec lobes on them and there is no reason for the smaller lobes so it runs on vtec all the time. This is done to shave weight off of the cams so that they can free up a little hp. The cams are called vtec killers.
Old 10-20-2003, 10:00 PM
also, vtec wasn't made for high hp, instead it was made for the economy
Old 10-20-2003, 10:02 PM
whtteg's Avatar
Re: v-tec
Originally Posted by hmooblis
also, vtec was't made for high hp, instead it was made for the economy
Ok newbie stop posting crap that is not true. Please stop posting stuff like this because it makes you look dumb
Old 10-20-2003, 10:08 PM
sorry but i'm trying to help right
Old 10-21-2003, 12:17 AM
LancasterWannaBe's Avatar
LancasterWannaBe LancasterWannaBe is offline
Send a message via AIM to LancasterWannaBe
there is an economy version VTEC...
Old 10-21-2003, 12:27 AM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
VTEC-E is in some older civics and I believe it is for economy. It actually disabled one of the 2 intake valves, and I read Honda was able to get A/F ratios of 20:1. GSRs, Type Rs and SIs are purely power, and apparently(from what I've read) VTEC is Hondas answer to turbocharging because they felt turbos didn't get enough fuel mileage. VTEC changes the valves timing, but depending on how it does that will depend on the results.
Old 10-21-2003, 12:30 AM
Spectre927's Avatar
The designed-for-power VTEC keeps the valves open more and longer letting in more air and fuel. You'll get noticeably less MPG if you hit VTEC a lot. Try it
Old 10-21-2003, 12:57 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: v-tec
but youre trying to help when you dont know what your talking about, someone could have read that post, which you phrase it like you know what your talking about, and then go out and buy a LS and not a GSR cuz he thinks it will be faster.
also doesnt the newer civic HX's have vtec e, just not the 3 stage like that old civic did.(if you arent sure put it like a question like I do )
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 10-21-2003, 01:14 AM
Spectre927's Avatar
Re: Re: v-tec
I think so(I never see it VTEC advertised with the HX). But Honda probably likes VTEC to be associated with power and wouldn't like somebody to think, "hey an HX has VTEC," then drive it, be dissapointed and talk smack. When the HX is under 2500, its only opening 1 valve and that valve is lifted higher and longer. At higher RPMS, both of the valves will take that higher and longer lift giving it a slight boost in power(if you buy a car solely for economy, you probably won't do this anyway). So I guess even the economy VTEC is better than no VTEC... naturally aspirated of course...
Old 10-21-2003, 03:34 AM
No Shit Sherlock! You at a higher RPM (like 6k right?) so even if you don't have a VTEC head you'll be getting way less mileage. LOL.
I don't think you can say "when you Hit VTEC" or "when VTEC kicks in" since variable valve timing isn't something that just "kicks in". Changing cam profiles doesn't mean you've hit VTEC or that you're now running on it, it just means the engine has multiple cam profiles and can vary between them, so they named it VTEC. It isn't some special point you reach or a button you push, it's just an engine design.
(None of this is to attack anyone BTW)
There's an article on Honda's VTEC in the engineering/technical forum:
http://www.automotiveforums.com/vbul...ad.php?t=77265
