Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-20-2003, 06:11 PM
davwlm davwlm is offline
Stalling Problems
I've got a '96 that's developing a stalling problem. After refueling, (only after refueling) the car, for the next ten miles or so, it wants to stall out when I slow down to turn or stop for a stop sign. Any ideas?
Thanks, Dave
Old 01-12-2004, 10:21 AM
johngalt52 johngalt52 is offline
Re: Stalling Problems
Thanks, Dave
Have you cleaned your throtle vlv lately? George
Old 05-22-2006, 11:48 PM
richter111 richter111 is offline
also make sure you are closing your fuel cap completely. Some Fords are set up to even throw the check engine light if the cap is not completely sealed.
Old 06-24-2006, 11:15 AM
Jackttt Jackttt is offline
Have you changed the gas line filter on the car, which is located
under the car. The way I see it, your fuel filter may be partially clogged,
and when you buy gas the vacum in the fuel tank is decreased causing
the fuel pump to work not as efficient, until the vacum is built up again
after a few miles of driving. Your fuel filter should be changed every
two years or more often if you are a driving more than normal. Changing
your filter will also help your fuel pump not to work as hard.
