Old 12-08-2001, 12:15 AM
highbrid highbrid is offline
Fuel System
Where exactly should I mount my inline fuel pump. Also is the b&m fuel pressure reg. just as good as any of the others or should i just go for the aem one. And finally what kind of fuel rail should I go with. I don't care about looks all I want is performance and above all reliability so if aem isn't the best tell me.:greenchai
Old 12-08-2001, 05:33 AM
texan's Avatar
texan texan is offline
Writer Mod
#1- Get an in-tank fuel pump, not an external. External pumps are anywhere from annoyingly to extremely loud, and any power level you look to be making that's streetable is easily served by an in-tank. The factory fuel pump on the B16A equipped Civic SI will support about 400hp at stock fuel pressure rates (provided you have large enough injectors).
#2- What modifications do you have that you need to jack up the fuel pressure?
#3- The stock fuel rals are good to at least 300hp, how much power are you making?
'03 Corvette Z06
'99 Prelude SH
Old 12-08-2001, 12:37 PM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
There is really no need for a new fuel rail except your ride is highly modified! If itīs not itīs just thrown out money.
Old 12-08-2001, 10:44 PM
Well I've got the gsr engine with ported and milled head, itr cams and all the bolt ons. I plan on going heavy nos so I just wanted to prepare my engine for it. Thanks for the advice on the rail.
What kinda injectors should i get?
Old 12-10-2001, 02:39 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Read the info on this site, and you can call them with any questions.
http://www.rceng.com/
They make good stuff.
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 10:24 PM
95 talon wont start - no fuel pressure eclipse787 Engine, Transmission and Drivetrain 2 05-08-2009 09:06 AM
HELP! - Problem - Fuel Economy/Fuel System jlbauer23 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 8 12-31-2003 10:15 AM
