Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 10-19-2003, 09:46 PM
gamezo gamezo is offline
Question question about the speedometer
Hey, everyone. I have this problem on my 1995 Jetta III city edition. It's the 2.0. My question is that the speedometer and the rev. meter dont work most of the time on it. The only time it works is after it has had a long time to cool off, it seems. As it usually works the first time I start the car in the mornings. But once I turn off the engine and start it anytime after that, it wont work. Any help would be very much appreciated. Also, if you could tell me about how much it would cost to fix, that would be great too. Thank you.
Oh, yeah. I forgot. JETTAS ROCK!!!!!!!!!!!!!!!!!!!!!!!
Old 10-20-2003, 10:05 AM
termitesgraffix's Avatar
termitesgraffix termitesgraffix is offline
Send a message via AIM to termitesgraffix
well speedometers work off a cable that spins, and the tachometer (not the revmeter) works off of an electrical pulse coming off your coil pack. so the problem off the two of them not working is two different problems. the speedometer cable is either loose or needs to be replaced. might need speedometer cable oil squirt in it. the tach may have a short in the wiring or be corroded???
Old 11-09-2003, 08:45 AM
HeirMuench HeirMuench is offline
Re: question about the speedometer
I have seen this problem in Jetta's. The Instrument cluster is actually electronic on this model. It has a ribbon circuit in the cluster itself. I usually just replace the cluster, labor is too high to replace the circuit itself. But this will fix your problem.
Old 07-29-2004, 08:01 AM
willgs willgs is offline
Question Re: Re: question about the speedometer
Any idea of $ to replace instrument cluster?
Old 07-29-2004, 12:41 PM
Well, I jus replaced the cluster and it seems to have fixed the problem, even though I do get ocassional complaints from it, but it might be the speed sensor going too. Anyway, the dealer sold the me cluster for roughly 260. If you don't mind the possibility of it not working, or if can get a guarantee of some sort, you can probably buy it online. I saw a new cluster for the 2000 Cabrio for 150 dollars.
