Old 10-19-2003, 08:34 PM
MoRsuS's Avatar
MoRsuS MoRsuS is offline
Can someone please tell me what "compression ratio" is?
What does it mean when a car is said to have (eg) a compression ratio of 9:0:1
Old 10-20-2003, 10:47 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: Can someone please tell me what "compression ratio" is?
that means that the cylinder volume at BDC is 9x the cylinder volume at TDC. If you also know what the total engine displacement is, you can calculate the TDC and BDC volumes.
Example:
CR = 9.6:1
4cyl, 1.6L displacement
displacement/cyl = 1.6L/4 = 0.4L
(vol.BDC)-(vol.TDC) = 0.4L
(vol.TDC)/(vol.BDC) = 1/9.6
vol.TDC = disp.cyl / (CR-1)
BDC volume = 0.4465
TDC volume = 0.0465
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 10-20-2003, 12:05 PM
MoRsuS's Avatar
Im sure that will make perfect sense as soon as i know what BDC and TDC stand for lol Care to explain ?
Old 10-20-2003, 12:10 PM
Jay! Jay! is offline
Horizontally Opposed
Top Dead Center and Bottom Dead Center. The 'top'most and 'bottom'most positions the piston will reach in a revolution, thus defining the maximum and minimum volume inside the cylinder.
Hierarchy of Subaru:
(Click to see mine!)
Old 10-20-2003, 12:17 PM
MoRsuS's Avatar
thanks a lot
Old 10-20-2003, 12:29 PM
MoRsuS's Avatar
One more question if i could: What are transmission ratios?(ie. 3.067 in first, 1.957 in second, 1.429 in third....etc)
Old 10-20-2003, 12:48 PM
Hudson Hudson is offline
Old Mod
Gear ratios are proportion of turns of the input shaft to turns of the output shaft. So a ratio of 3.067(:1) means 3.067 turns of the input (the crankshaft) will turn the output shaft one time.
Old 03-21-2004, 01:53 PM
jhillyer jhillyer is offline
What is compression ratio, 9:1
It's a ratio of how much cylinder volume has been pressed at the end of the piston stroke toward the ignition end of the cylinder. A simple view: If the travel of a piston through a cylinder were 90mm long with a flat cylinder head, and the piston reached end of its travel 10mm short of the end of that cylinder, then a 10mm gap of unstroked cylinder would remain when that piston reaches end of its stroke, creating a 9:1 pressure, or 9 atmospheres, leaving a 10mm combustion chamber. Also see "final compression" or "effective compression" ratio when turbocharging. Compression ration can be adjusted by valve timing, stroke, head chamber volume, spark or glow plug, ....
You're wasting time reading this, move onward to the next thread.
