Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 10-19-2003, 04:41 PM
biggruss94civic biggruss94civic is offline
halo lights
i have denji halo headlights for my 94 honda civic
when i turn on my headlights my lights inside dim did i do something wrong should i get a bigger battery
Old 10-19-2003, 06:09 PM
ra227 ra227 is offline
Do you have the dimmer switch inside the car set to a low level? Be funny as hell if that is all it was.
Old 10-20-2003, 02:27 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Did you just get this car and did it come with the halos already installed?
ECNATSISER AL AVIV
Old 10-20-2003, 02:43 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: halo lights
has to be. I've done it before and spent forever digging through wires, fuses, etc... and that's what it ended up being. I punched myself in the nuts and moved on.
Old 10-20-2003, 02:50 PM
Mendari Mendari is offline
We need a little more background info on your car. Was it ever in an accident? If so, the electrical grounding system may have been damaged during the collision/repair. If not, then you may require a capacitor to handle the extra electrical current being drawn by the new headlights.
First things first; If you plan on performing electrical work, purchase a voltimeter. They range from $18 - $300+. But don't worry, a cheap one from Radio Shack works great. You'll need to do 2 tests, both with the engine off. Turn on your headlights an measure the voltage drop using your O.E. headlights. Turn off your headlights, install your fancy headlights, turn on your headlights and measure the voltage drop.
Your O.E. headlights will drop voltage briefly then return to the normal level. Your fancy headlights should behave the same. However, if your fancy headlights lower the voltage but do not return to the normal level, you will need a capacitor.
Old 10-21-2003, 07:18 PM
Re: Re: halo lights
OUCH!!!
Hey biggruss... I have halos and have not encountered that problem. My clock dims when the headlights are turned on but thats normal. What Mendari suggested sounds all technical so that might work. Also what lights exactly, the dash lights, clock... what... everything. I would suggest getting a professional to look at it or a friend to go over your work. It might be something obvious that a different pair of eyes might notice. Hope it works, or has worked, out.
Old 10-21-2003, 08:00 PM
Ricochet's Avatar
Banned
Re: Re: Re: halo lights
Or you could buy one of those $100 grounding kits. At a shop where a couple friends work, they dynoed a car before/after and it actually bumped up 7whp...
