Old 10-19-2003, 11:38 AM
intak420 intak420 is offline
Question Check Gauges??
I have a 1993 Grand Prix SE 3.1.
Every once in a while my car will stall ( usually at a stop light) just out of the blue. When It does this my check gauges light comes on.
The car usually restarts fine without further trouble. Occasionally , I will have to restart it 2 or 3 times then it is fine.
Also, all of my lights flicker all the time: headlights, gauges ect.
The problem gets worse when I press on the brake pedal.
Thank everyone in advance for ideas!!
Old 10-19-2003, 01:45 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Possible bad altenator/battery.
I would try and find out what code the car is pulling when the car stalls and then go from there.
Old 11-18-2003, 05:30 PM
92GPSE24VTDOHCV6 92GPSE24VTDOHCV6 is offline
I have a 92 SE 3.4, and my Check Gauges and Low Fuel light are always on. They have turned off a few times for a few seconds in the two years I've had the car. I was told it was a design flaw in the electronics and that it is common in Grand Prixs around that year. My doesn't stall, though. My lights dim a little when I press the brakes, but my alternator and battery are less than a year old.
Old 03-11-2004, 01:32 AM
Wraithchild Wraithchild is offline
Send a message via AIM to Wraithchild
Re: Check Gauges??
I had the same problem in my GP with the check gauges and low fuel light I found a site did what it said and it fixed the problem for me. http://www.w-body.com/ its in problems repairs and prevention on the main page. btw its a cold solder in your gauges.
Old 03-11-2004, 05:44 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: Check Gauges??
Well I will go better with Ripn12s. When the lights flicker all the time is related to the voltage regulator on the alternator. This piece of hardware would make sure that the A/C current being developed at the alternator windings gets converted to an almost D/C current at the alternator output. When you see the lights flickering is that the ripple being let out on the D/C current is really higher than what the car ECU(PCM) and other equipment is prepared to whistand. The ligths dimming when hitting the brakes are related to a really loaded electrical circuit or starting to fade battery
4R55E Front End Play Check Gauge Bar T93T-77003-AH mrstubb Explorer | Explorer Sport Trac 0 06-13-2010 02:59 AM
check washer fluid and check gauges light brightens with engine rev HotRod53 Bonneville 0 03-17-2010 07:12 AM
check gauges light blinks all the time and nothing wrong with gauges chevyrulespops Grand AM 1 10-01-2008 11:04 AM
Check Gauges light on Fuel Gauge Falls..HELP!! Bleednstar Cavalier Problem Diagnosis 1 06-05-2005 07:19 PM
2001 Expolrer-Check Gauge Light/Temp Gauge cmroth12 Explorer | Explorer Sport Trac 0 12-29-2003 01:11 PM
