Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 10-19-2003, 01:37 AM
sdnicker sdnicker is offline
305/350 Heads
I would like to put a 350 in place of my stock 305 HO in my Camero. Would the heads off of the 305 work on the 350? From what I understand the 305 HO has larger valves. The 350 is out of street-stock racecar that got T-Boned the first race. The heads on this engine would not allow pump gasoline due to too high of compression.
If anyone knows please let me know. Thanks
Old 11-22-2003, 02:03 AM
ra11585643 ra11585643 is offline
Re: 305/350 Heads
Need more info, what year engines, casting numbers on engines and heads. And if it was mine id check on gasoline alternatives and do a complete swap to keep the compression if possible.
Old 11-25-2003, 06:05 PM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Re: 305/350 Heads
Really I had a that combo in a 75 vette worked great! But if you going to drive it on the street you need to be able to run on pump gas. I was at 11 and half on my vette could only run pemium.
350 4bolt with 305 tpi heads 1963chevypudriver Engineering/ Technical 2 12-21-2005 01:32 PM
350 heads on a 305? jonsonton Camaro Discussions 3 04-30-2005 07:45 AM
305 heads vs. 350 heads bobboinge Blazer 4 02-11-2005 02:32 PM
350 heads on a 305? faulkner32 C/K 7 10-06-2004 10:13 AM
305/350 Heads sdnicker Camaro Discussions 0 10-18-2003 07:21 PM
