Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-18-2003, 09:53 AM
drvncrzy drvncrzy is offline
Unhappy Heater problems!!!!!!!!!!!!!!!!!!!!!!!!
MY heater was working fine until the other day now it wont get hot, just blows cold air......anyone have a suggestion????????? its a 95 limited with 4.0
Old 10-18-2003, 07:21 PM
bustedratchet bustedratchet is offline
Re: Heater problems!!!!!!!!!!!!!!!!!!!!!!!!
Is it full of coolant ? if so do the hoses get hot? is the temp gauge reading normal ? Is it climate control or manual ?
Old 10-21-2003, 03:54 PM
Question
Its Is Climate Controled And Its Is Running Up To Temp,,,now I Figured Out If I Turn The Ac On Then Turn The Heat On It Worked Weird Huh
Old 10-23-2003, 06:18 AM
Re: Heat!!!!!
Yeah that is weird! I'd try back flushing the heater core first. If thats not it you may have to get under the dash and watch to see if the blend door is working.You might wind up getting it looked at for a temp sensor or something.
Old 10-29-2003, 08:35 AM
max82 max82 is offline
Re: Re: Heat!!!!!
check your blend door or your actuator
Old 12-10-2003, 09:09 AM
Burnsy Burnsy is offline
Heat
I have just had the same problem and it appears to be the vent/blend door is stuck. I was told to fix it would cost 825 bucks to get the dash off and install a new part... Ouch... I hate Ford!
