Old 10-17-2003, 10:16 PM
TriPocalypse666 TriPocalypse666 is offline
headlights??
would there possibley be anyway to change the color of the headlight tubing........my 3000gt is red and the tubing came red.....i want to change it to black....how would i do this????.....by tubing i mean the piece that surrounds the headlights
Old 10-20-2003, 02:08 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
What year do you have?
Old 10-20-2003, 04:38 PM
1994......if anyone else knows.....hit up this thread
Old 10-20-2003, 09:34 PM
lucky you, 94 is the only year you can paint the inside of the lights. You will have to pull the glass off of the headlight and paint the inside. There are various directions online, what I found to work best is:
preheat an over to 250
remove metal clips, and any mounting brackets
put a headlight on a cookie sheet and put in oven for 10 min
remove from oven and use 2 screwdrivers to slowly pry the glass off
the silicone glue will be hot and melted, so it will strech
cut the silicone with some scissors and makes sure it doesnt touch the painted area
once you get the glass off you can paint it however you want
to reassemble:
even out the silicone and set the glass back on the headlight
put back in the over for 10 minutes
when you pull it out, push the glass down slightly and put clips back on the headlight
