I need correct GM part# for Computer
I have a 1989 Buick Lasabre. The guy at the junkyard said 88-91 GM 3800 series computer would work. I bought it in case my computer was bad and or to have a spare.
I took a 'puter out of a 91 Olds regency with a 3.8 service # 01228253 which I have not installed yet. I have a 39 code and a 41 code. Cam sensor. . .hmm engine runs fine. Shifts a bit too much going up hills. Any ideas. Craig [email protected] |
Re: I need correct GM part# for Computer
The 1228253 computer sounds like the correct part number..BUT they were JUNK...caused many driveability problems..call your GM parts department and give them the number..they can give you the new part number.
There is a magnet on the cam gear that triggers the sensor, the magnet has been know to desinigrate and set a 41. Remove the cam sensor and spin the engine over by hand while watching the cam gear...you should see the magnet or where it should have been. If it is missing, thats the cause of your 41.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Re: Re: I need correct GM part# for Computer
Did you switch the proms in the computers?
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
Re: Re: Re: I need correct GM part# for Computer
I reset the existing computer by unhooking the battery for an hour. It immediately brought up the 39 and 41 code. Where is this cam sensor located? Craig [email protected] |
Re: Re: Re: Re: I need correct GM part# for Computer
Cam sensor is located on the right side (passenger)of the engine under and slightly to the rear of the waterpump.
You will see the wires going to it. It may be easier to remove the serpentine belt get get better acces to it. 10 mm bolt holds the sensor to the timing cover.
