Old 10-17-2003, 10:06 PM
cteneyck cteneyck is offline
ZC engine problems
i just put a zc sohc enging in my 89 civic dx and i cannot get it to fire.
i was told by the guy that sold me the engine that all i had to do was put my old intake, exhaust and distributor on the zc block and reconnect the wire harness and it would work fine. but i am not getting any spark from the distributor. plz help. thanks
Old 10-17-2003, 11:37 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
not sure if the stock dx ecu will work or not that could be it.
Old 10-18-2003, 12:31 AM
91zc 91zc is offline
Your problem is you are trying to run multipoint fuel injected motor(4 fuel injectors, with a wiring and harness and ecu designed to run a dual point fuel injected engine(two injectors). Do a search on here for mpfi and you should find some good info on how to convert your current wiring harness to run your zc. You will also need a new ecu. You can use any obd0 mpfi ecu ie 88-91 civic/crx si, 88-89 integra etc.
91 civic 4dr
b16a
14.8@94
Old 10-18-2003, 03:20 AM
not using the mpfi
i am using the dpfi right now. that way i can keep it simple with the connections. the engine will turn over but there is no spark at the spark plugs nothing coming out of the distributor. all the connections should be the same. so i don't see whats the problem.
Old 10-18-2003, 10:57 AM
Ok my bad I didn't know you were using dpfi. Make sure all your grounds are good and then make sure all connections are tight and that the distributor is good.
91 civic 4dr
b16a
14.8@94
Old 10-18-2003, 12:09 PM
ok thanks
just curious about something though. i was told that so long as i use intake man, exhaust man, and distributor that came off the old d15b2 then i shouldn't have a problem with getting the engine to start. is this true whats your recomendations. ps horse power isn't my main concern this is my sisters car and am just trying to get her back on the road...
thanks
Old 10-18-2003, 07:01 PM
problem solved
distrib was bad and a relay went bad.
smooth running and nice take off too...
Old 10-18-2003, 07:07 PM
Good to hear it was something pretty simple.
91 civic 4dr
b16a
14.8@94
