Old 10-17-2003, 09:32 PM
ooljima ooljima is offline
Send a message via AIM to ooljima
now what should i do?
apex'i bov/ injen intake/ apex'i n1...... ok..... three things.... now what?????? some advice and suggestions.... so far yall been helpful. and does anybody know good spark plugs and spark plug wires for the 2g?
Old 10-17-2003, 11:28 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: now what should i do?
3' down pipe, 255lb fuel pump greddy profec b, apex s-afc, denso makes nice plugs and nology wires are always good.. portered 02 housing... ect.
1
Shift_BOOST
97 s14
Old 10-18-2003, 12:21 AM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Stick with NGK plugs, BPR6ES to be specific. NGK makes good wires too, too bad they only come in blue. Keep an eye on those plugs, they will become fouled quicker than usual since you are venting your BOV
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 10-18-2003, 02:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
I run stock wires in the 11s. Every wire type I have tried cant fire under boost, except a set of NGKs I ran for a week or so. Take talons advice on plugs. People run 10s on those things if not lower.
HAve you replaced the shyte 2g upper IC pipe? Your next mod could be a fuel pump, then boost control. Then the downpipe. After that its time for a datalogger and fuel control before finally upgrading that turbo.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-18-2003, 03:39 AM
o.... fuel pump eh?.... well... will the fuel pump be difficult to install by myself? i've done everything myself till now.. i wanna do as much as possible cuz i dont trust them shops...
Old 10-18-2003, 07:31 AM
AF - Advisor
GOOD. I dont trust them "shops" either. www.vfaq.com will be your new favorite website. Everything you need is there, of you have some idea what you are doing around cars. When I bought my DSM, I was scared to change a clutch. Now after doing 40 of them, motor swaps, 6 bolt conversions, countless turbo installs, custom fab my own exhaust, etc.... It all starts with the vfaqs
Kevin Jewer
Old 10-18-2003, 02:21 PM
Re: Re: now what should i do?
anybody know anything about the apex'i downpipe? does it eliminate the cat?... cuz i want a high flow cat and a downpipe.... any suggestions?
Old 10-18-2003, 02:32 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
http://www.rnrracing.com/
-Agim
