Old 10-17-2003, 06:31 PM
wenster wenster is offline
Question Confused about the D16Y7....
First of all, I was just curious about developments in the turner world.
I stumble across some forums discussing the "potentials" of the D16Y7 engine. Now, knowing that an automatic transmission plus the Y7 engine makes a really bad combination, I'm just thinking what ARE the "potentials" of this engine.
Couple of years ago, I was interesting in tuning this little commuter up but was pretty must disappointed at the response of "swap the engine". I don't plan to swap until my engine blows up. So, I've pretty much given up on most mods.... but now..
So, what exactly are people doing with their Y7 engines? And what kind of increased performance would be expected? Honestly, I wouldn't mind a little boost on my little commuter. Especially if I feel sluggish while carry 2 people in the car with A/C on.
Thanks!
Beat up, dusty, tinted commuter...
'98 Civic Coupe DX (auto tranny)
-K&N Typhoon Intake
-Tokico Shocks
Old 10-17-2003, 06:36 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Re: Confused about the D16Y7....
People like me with the Y7 engine are swapping it out
and boost would be my second choice, can't go wrong with turbo.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 10-17-2003, 08:29 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: Confused about the D16Y7....
If you have a ton of money you need to get rid of, turbocharge it. Otherwise save up and SWAP.
Old 10-18-2003, 05:05 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: Re: Confused about the D16Y7....
Im not gonna start on swaps. I'll just say it's the easiest way to get an extra 30-40 hp.
We can start with your tranny first... You can either swap out for a D-series manual tranny, or if you like your auto, you can opt to get a Level10 or TCI torque converter replacement. It'll crank up the stall speed of the tranny by about 500 RPMs, and give it WAY quicker shifts, in some cases quicker auto shifts than one can do by hand with a manual.
As for your motor, I have the same exact one so you aren't alone. What I plan on doing is getting a cam here soon from www.deltacam.com which should up things by about 15hp or so, and only for a mere $65. You can swap out heads and pistons to chang compression ratios for various setups. If you get a sleeve kit or block guard, you can boost that motor up to and even past 300hp! Without sleeving, the motor can handle up to about 200hp before ANY internals like the crank, rods or pistons need to be upgraded. I've seen a couple D15 motors withstand 220 whp with a 50shot of nitrous on stock internals, but any higher and all hell would break loose inside there. I'm also planning to turbo my motor down the line here as well. Nothing that will shatter track times, but something to give it more umph, so about a 50-60hp gain is what I'm looking for. Nothing that would require swapping of internal parts since I'd keep the boost to stock friendly pressures.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 10-18-2003, 11:37 PM
91civicDXdude's Avatar
swap a D16Y8 intake manifold on, CAI, header, exhaust. that should put you about 110-115hp.
You could swap a SOHC VTEC head on the block, wiht the y8 manifold and bolt ons, and be around 130-135hp.
You could also throw a shot of nitrous, 35 or 50 shot.
The D16Y7 engine with a D16Y8 intake manifold is pretty similar to the older D16A6 engine, only the Y7 has bigger valves so you should be quicker than a d16a6, which is 108hp. One of the things i would definately recommend is getting the d16y8 manifold. the Y7 manifold has little to no plenum and is not very good for horsepower gains.
I'd say get a SOHC VTEC head and intake, I/H/E, stage 2 zex cam.. you should be around 145-150hp or so. a lot of these mods can be had with great deals. search around.
Old 10-19-2003, 01:51 AM
mengy mengy is offline
hmm i'm wondering can i do the same to my little d15b7... which intake manifold, throttle body.. can i swap into it to make/handle some good gains? if any... right now I'm running only Intake and exhaust... gains are okay.. but more is better
Old 10-19-2003, 11:50 AM
Thumbs up Dudes!
Needless to say... you guys are true geniouses.
Thanks! I'll start looking around.
-K&N Typhoon Intake
-Tokico Shocks
