Old 10-17-2003, 06:00 PM
ButterMule ButterMule is offline
Send a message via AIM to ButterMule
Transmission problems
my si transmission makes noise at idle and is real noisey when i take off.. the noise goes away when i push the clutch in.. is it the throw out bearing? if so how much is something like that to get fixed?
Old 10-17-2003, 09:07 PM
crxpace crxpace is offline
Smile
It could be a number of things but i would start with the throw-out bearing it's probably shot. Also while you have the tranny out check the seals. If you have a shop do the work it will run about 250 to 400 depending on the area. If you have a shop do it you might as well replace the whole clutch while it's cracked open.
Peace Bro
Old 10-18-2003, 12:49 AM
BullShifter's Avatar
Re: Transmission problems
Its not the throw out bearing, its the input shaft bearing. Instead of rebuilding your current trans, just buy a rebuilt trans with warranty & install that. Most decent shop would open your transmission & replace all worn parts(expensive & have to wait for parts to be ordered after trans is open) - bearings, 2nd/3rd gear/synchros & anything else that needs replacing, aint worth the $$$$ IMO since you can get a rebuilt trans for cheap(around $300).
Old 05-06-2006, 09:14 PM
skate1968 skate1968 is offline
Originally Posted by BullShifter
...just buy a rebuilt trans with warranty & install that. ...bearings, 2nd/3rd gear/synchros & anything else that needs replacing, aint worth the $$$$ IMO since you can get a rebuilt trans for cheap(around $300).
Bull,
LOVE this idea. And if I can find a rebuilt trans for around 300 w/ some warranty I will grab it in a second.
Wish me luck.
(my trans is starting to make more noise. shifts fine, but noise is progressively worse. NOT leaking fluid like i thought earlier. time to start looking)
skate
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
