Old 10-17-2003, 03:28 PM
rinapr rinapr is offline
check engine light ON
My check engine light has been on for about a month, I have a 2000 Accord SE, But the car is driving fine. I was told by a mechanic it would cost be around 450 dollars to fix the sensor as he figured the sensor had gone bad. But I am not sure about what he says, would it be trouble with the engine?
A honda service person just opened the gas cap and put it back, it obviously didnt work.
i would be very grateful for any helful suggestions....
Thanks a lot in advance....
Old 10-17-2003, 04:34 PM
under advisement under advisement is offline
The "check engine light" represents an emissions problem. Often it's a bad oxygen sensor or a bad cat, or a plugged egr. It's fairly hard to tell without actually pulling the code what the problem is though.
Old 10-17-2003, 06:24 PM
HONDA_99 HONDA_99 is offline
Re: check engine light ON
this is copy from haynes manual on how to do diagnostics and reset ECU.
here link to album for bigger pictures
http://www.imagestation.com/album/?i...52271603&idx=3
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 10-20-2003, 08:01 AM
If it is a bad oxygen sensor how much would it cost to get it repaired? I was told it might cost me around $450. Does that seem ok ?
Thanks a lot!
Old 10-21-2003, 11:34 PM
AngryTroll AngryTroll is offline
Re: Re: check engine light ON
Thanks a lot!
Did you take it to a Honda dealer? Guessing will cost you money.
What trouble code was stored? An aftermarket shop will have no idea how to fix a P0133.
If I knew the trouble code, I could be more helpful...
Old 10-22-2003, 10:16 AM
Re: Re: Re: check engine light ON
a lot parts in emission system covered by Honda's 8/80,000 warranty, that includes O2 sensor, catalytic converter and etc.
check your warranty manual to find out what exactly has extanded warranty. then check what trouble code is stored in ECU and if that system covered under warranty take your car to dealer.
