Old 10-17-2003, 01:12 PM
4g/6g 4g/6g is offline
Question Bad trans
Has anybody ever rebuilt a manuel trans. Mine falls out of third gear and grinds when downshifting to fouth. Ive been told its the sincros. I was wondering would it be worth rebuilding or just buy another.
Old 10-17-2003, 02:13 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Bad trans
definetely not worth rebuilding. I got quoted over 1k to rebuild my auto tranny, went out and got a jdm auto tranny from a d15b for 150, took me and my dad and his friend three hours in and out, and the tranny works perfectly.
Empty Pockets Racing Member #1
Old 10-17-2003, 02:38 PM
ok thanks i figured that be the easiest method
Old 10-17-2003, 03:56 PM
Jeff C's Avatar
Jeff C Jeff C is offline
First of all, manuals are a lot easier that autos. You can buy synchro kits here. I have been in numerous manual trannies for various reasons. I rebuilt my 92 GSR tranny and it was a cake walk.
However, you can probably find a tranny in a junkyard for around $100, maybe.
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-17-2003, 04:05 PM
im not sure that the synchros are the problem. I guess ill have to pull it apart
Old 10-17-2003, 04:11 PM
Jeff C's Avatar
You have nothing to loose.
Here is a recent tranny thead on another board that I did when I pulled mine apart...link. Maybe it will help.
Old 10-17-2003, 04:20 PM
thanks for the link. I allways get a little scared doing stuff like that at home
Old 10-17-2003, 04:44 PM
crxpace crxpace is offline
just buy a tranny from a junkyard it's cheaper not unless you plan on keeping the D series for along while. I junkyard tranny will work fine. I would not pay more then 125 for that tranny. They are a dime a dozen and very common. I threw a couple away last year bad timing i guess i would have shipped it to you.
Peace Bro
Old 10-17-2003, 04:51 PM
the only problem with that is if i get one with the same problem. i guess ill take the risk
Old 10-17-2003, 05:09 PM
well first double check your linkage on your car then if it's cool. get a junkyard tranny pull yours out first and check the wear and tolorences. So you can compare it to the junkyard tranny. Look for leaks and movement in the shaft also if you go with a friend he can spin the shaft while you go thru the gears. If it shifts smoothly chances are it's good. If it does not they it was probably curbed. Meaning the wheel jacked the tranny.
Peace Bro
Old 10-17-2003, 05:18 PM
im looking to sell the car soon anyway so thats probally what ill do
thanks
